girkers
(Girkers)
January 29, 2023, 5:33am
1
I am really confused on how to configure my fan right now.
I have a Lucci Connect Remote: https://templates.blakadder.com/luci-connect-remote-control.html
and with it configured to Tasmota detection, HA detects it as a fan, but I have not options to change the speed, only a switch to turn it on and off.
Adding the configuration as set out in the above link doesn’t work and I have tried using the Developer Tools as per https://www.home-assistant.io/integrations/fan/ but nothing happens on my fan.
My fan supports 3 speeds and use to work perfectly with MQTT.
A bit lost as to where to start, I appreciate that HA has changed Fans alot over the last year or so, but I have absolutely no idea on where to start to get my fan configured so I can set the speed of it.
girkers
(Girkers)
May 25, 2023, 3:37am
2
With all the updates to Fans, I am still no closer to getting speeds for my fans, any ideas?
girkers
(Girkers)
July 21, 2023, 12:14am
3
I was finally able to figure it out using this page: Martin Jerry Fan Speed Controller US-FC-01 | digiblurDIY
My old configuration worked, i just had to get the top bit right, this is what my configuration looks like now:
mqtt:
fan:
- name: "Main Ceiling Fan"
state_topic: "stat/main_cf/POWER1"
command_topic: "cmnd/main_cf/POWER1"
payload_on: "ON"
payload_off: "OFF"
availability_topic: "tele/main_cf/LWT"
payload_available: "Online"
payload_not_available: "Offline"
preset_mode_state_topic: "stat/main_cf/speed"
preset_mode_value_template: >
{%- if value == '2,0' %}low
{%- elif value == '2,1' %}medium
{%- elif value == '2,2' %}high
{%- endif -%}
preset_mode_command_topic: "cmnd/main_cf/TuyaSend4"
preset_mode_command_template: >
{%- if value == "low" %}2,0
{%- elif value == "medium" %}2,1
{%- elif value == "high" %}2,2
{%- endif -%}
qos: 0
preset_modes:
- "low"
- "medium"
- "high"
