Hi All
Iam starting to use this hassio + tasmota 2 weeks its a wery good software, Thank you all to do this !
Iam using Tasmota and writing script in nodered.
Iam using this swith for socket, and watering sytem.
I have a question, what happends is my socket turned on, or watering turned on , and in some way the router is broken ? Is that menas the relay remain ON, so the watering is going forever.
I check the PulseTime1 command its wokring, so this is resolving my problem but.
In the nodered when the switch is turnening on, when that evet genereates I send a command to the tasmota,: cmnd/sonoff1/PulseTime1 100
But if I send this PulseTime1 after the command switch ON it does not take effect.
SO is that possibile to send switch ON command together with timeout ? ( 0 means never turned OFF, or time meanes turned OFF aoutomaticaly after thet time ) ?
