Wonder if anyone has experienced the following and knows how to correct.
I installed the Tasmota firmware on a Sonoff 4Ch Pro.
I used the setoption19 1 from the consol to auto register the channels with HA, having applied names to each of the channels.
All worked and the entities appeared in HA.
Later I decided that the channel names were not appropriate (stupid I know, but…) so having tried re-naming them in Sonoff and seeing that not picked up in HA (mutiple re-boots etc.) I decided to start from scratch, deleted the entities and the integration and MQTT and started again (including re-setting the Sonoff).
The 4 channels however will not re-appear in HA. I tried the setoption19 1 again, I get the following response at the sonoff end;
13:14:45 MQT: stat/tasmota_C497E3/RESULT = {"SetOption19":"ON"}
13:14:45 MQT: homeassistant/device_automation/C497E3_SW_4_TOGGLE/config = (retained)
13:14:45 MQT: homeassistant/device_automation/C497E3_SW_4_HOLD/config = (retained)
13:14:45 MQT: homeassistant/binary_sensor/C497E3_SW_4/config = (retained)
13:14:45 MQT: homeassistant/device_automation/C497E3_SW_5_TOGGLE/config = (retained)
13:14:45 MQT: homeassistant/device_automation/C497E3_SW_5_HOLD/config = (retained)
13:14:45 MQT: homeassistant/binary_sensor/C497E3_SW_5/config = (retained)
13:14:45 MQT: homeassistant/device_automation/C497E3_SW_6_TOGGLE/config = (retained)
13:14:45 MQT: homeassistant/device_automation/C497E3_SW_6_HOLD/config = (retained)
13:14:45 MQT: homeassistant/binary_sensor/C497E3_SW_6/config = (retained)
13:14:45 MQT: homeassistant/device_automation/C497E3_SW_7_TOGGLE/config = (retained)
13:14:45 MQT: homeassistant/device_automation/C497E3_SW_7_HOLD/config = (retained)
13:14:45 MQT: homeassistant/binary_sensor/C497E3_SW_7/config = (retained)
13:14:45 MQT: homeassistant/device_automation/C497E3_SW_8_TOGGLE/config = (retained)
13:14:45 MQT: homeassistant/device_automation/C497E3_SW_8_HOLD/config = (retained)
13:14:45 MQT: homeassistant/binary_sensor/C497E3_SW_8/config = (retained)
13:14:45 MQT: homeassistant/light/C497E3_LI_1/config = (retained)
13:14:45 MQT: homeassistant/switch/C497E3_RL_1/config = {"name":"Tasmota_Garden_1","stat_t":"tele/tasmota_C497E3/STATE","avty_t":"tele/tasmota_C497E3/LWT","pl_avail":"Online","pl_not_avail":"Offline","cmd_t":"cmnd/tasmota_C497E3/POWER1","val_tpl":"{{value_json.POWER1}}","pl_off":"OFF","pl_on":"ON","uniq_id":"C497E3_RL_1","dev":{"ids":["C497E3"]}} (retained)
13:14:45 MQT: homeassistant/light/C497E3_LI_2/config = (retained)
13:14:45 MQT: homeassistant/switch/C497E3_RL_2/config = {"name":"Tasmota_Garden_2","stat_t":"tele/tasmota_C497E3/STATE","avty_t":"tele/tasmota_C497E3/LWT","pl_avail":"Online","pl_not_avail":"Offline","cmd_t":"cmnd/tasmota_C497E3/POWER2","val_tpl":"{{value_json.POWER2}}","pl_off":"OFF","pl_on":"ON","uniq_id":"C497E3_RL_2","dev":{"ids":["C497E3"]}} (retained)
13:14:45 MQT: homeassistant/light/C497E3_LI_3/config = (retained)
13:14:45 MQT: homeassistant/switch/C497E3_RL_3/config = {"name":"Tasmota_Garden_3","stat_t":"tele/tasmota_C497E3/STATE","avty_t":"tele/tasmota_C497E3/LWT","pl_avail":"Online","pl_not_avail":"Offline","cmd_t":"cmnd/tasmota_C497E3/POWER3","val_tpl":"{{value_json.POWER3}}","pl_off":"OFF","pl_on":"ON","uniq_id":"C497E3_RL_3","dev":{"ids":["C497E3"]}} (retained)
13:14:45 MQT: homeassistant/light/C497E3_LI_4/config = (retained)
13:14:45 MQT: homeassistant/switch/C497E3_RL_4/config = {"name":"Tasmota_Garden_4","stat_t":"tele/tasmota_C497E3/STATE","avty_t":"tele/tasmota_C497E3/LWT","pl_avail":"Online","pl_not_avail":"Offline","cmd_t":"cmnd/tasmota_C497E3/POWER4","val_tpl":"{{value_json.POWER4}}","pl_off":"OFF","pl_on":"ON","uniq_id":"C497E3_RL_4","dev":{"ids":["C497E3"]}} (retained)
13:14:45 MQT: homeassistant/light/C497E3_LI_5/config = (retained)
13:14:45 MQT: homeassistant/switch/C497E3_RL_5/config = (retained)
13:14:45 MQT: homeassistant/light/C497E3_LI_6/config = (retained)
13:14:45 MQT: homeassistant/switch/C497E3_RL_6/config = (retained)
13:14:45 MQT: homeassistant/light/C497E3_LI_7/config = (retained)
13:14:45 MQT: homeassistant/switch/C497E3_RL_7/config = (retained)
13:14:45 MQT: homeassistant/light/C497E3_LI_8/config = (retained)
13:14:45 MQT: homeassistant/switch/C497E3_RL_8/config = (retained)
13:14:45 MQT: homeassistant/sensor/C497E3_status/config = {"name":"Sonoff 4CH Pro status","stat_t":"tele/tasmota_C497E3/HASS_STATE","avty_t":"tele/tasmota_C497E3/LWT","pl_avail":"Online","pl_not_avail":"Offline","json_attr_t":"tele/tasmota_C497E3/HASS_STATE","unit_of_meas":"%","val_tpl":"{{value_json['RSSI']}}","ic":"mdi:information-outline","uniq_id":"C497E3_status","dev":{"ids":["C497E3"],"name":"Sonoff 4CH Pro","mdl":"Sonoff 4CH Pro","sw":"8.3.0(tasmota)","mf":"Tasmota"}} (retained)
Is there a way to force this or am I doing something obviously wrong? Appreciate being pointed in the right direction.
