Tasmota integration with DeepSleep mode
With the Tasmota integration, devices that use deepsleep mode appear as unavailable.
ha_tasmo
If you encounter this issue, you need to manually recreate all the sensors to address this problem.
Since version 13.1.0, a new MQTT topic for managing with the deepsleep mode has been created by Tasmota to facilitate integration with HA : New DEEPSLEEP topic for HA + Battery Level % support by stefanbode · Pull Request #19134 · arendst/Tasmota · GitHub
Is it possible to anticipate this update soon?
It would greatly facilitate the configuration of such devices under HA.
BR.
A.
There’s an open PR which adds this support #263 observe deep sleep and keep sensors always available by fra-orolo · Pull Request #264 · emontnemery/hatasmota · GitHub
However, the PR is not using the new MQTT topic for managing deepsleep.
We already have in the discovery message a dslp 1 or 0 to propagate to home assistant that the device may behave different. Anyhow the current integration need major change because “offline” on LWT is not offline anymore if dspl=1. I assume the solution with the minimal change would be to assume devices with dspl=1 are always online and just skip the offline. So these will never go offline.
