MY Blitzwolf bulbs that have been converted to Tasmota (9.2) will not change colour in the HA picker, each time I select a colour they pop back to the center white. I can change them no problem from the direct IP address. It may be they changed IP through the DHCP although they kept working. I have not changed anything and am running all latest versions. I tried deleting and rediscovering but still the same. Any advice appreciated
Hello David,
did you sort it out you issue with tasmota and the collor always change to white ?
I have same issue.
Radek
No I didn’t They ultimately became undiscoverable and were only good for the bin.
