Hi, I have an issue that my Sonoff Mini start switching insanely for about two seconds when I switch it off by the mechanical switch. It does not happening when I am switching it using HA. Have anybody else experienced the same? I tried to play with the GPIO association but not change.
00:00:00.045 CFG: Staženo z paměti flash z FB, Počítej 242
00:00:00.139 QPC: Reset
00:00:00.146 Projekt tasmota Bathroom fan Verze 9.3.1(tasmota)-2_7_4_9(2021-03-09T16:14:51)
00:00:00.734 WIF: Připojování k AP1 BIOSPACE Channel 4 BSSId C0:C9:E3:8C:64:A7 v módu 11n jako tasmota-7328...
00:00:01.753 WIF: ...připojeno
00:00:02.006 HTP: Aktivní Web server tasmota-7328 na IP adrese 192.168.2.204
09:45:47.041 MQT: Připojování...
09:45:47.055 MQT: ...připojeno
09:45:47.057 MQT: tele/tasmota/LWT = Online (Zachováno)
09:45:47.059 MQT: cmnd/tasmota/POWER =
09:45:47.072 MQT: tele/tasmota/INFO1 = {"Module":"Sonoff Basic","Version":"9.3.1(tasmota)","FallbackTopic":"cmnd/DVES_8BDCA0_fb/","GroupTopic":"cmnd/tasmotas/"}
09:45:47.079 MQT: tele/tasmota/INFO2 = {"WebServerMode":"Admin","Hostname":"tasmota-7328","IPAddress":"192.168.2.204"}
09:45:47.088 MQT: tele/tasmota/INFO3 = {"RestartReason":"Software/System restart"}
09:45:47.095 MQT: stat/tasmota/RESULT = {"POWER":"OFF"}
09:45:47.099 MQT: stat/tasmota/POWER = OFF
09:45:48.118 MQT: stat/tasmota/RESULT = {"Time":"2021-03-21T09:45:48","Uptime":"0T00:00:06","UptimeSec":6,"Heap":28,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":22,"MqttCount":1,"POWER":"OFF","Wifi":{"AP":1,"SSId":"BIOSPACE","BSSId":"C0:C9:E3:8C:64:A7","Channel":4,"RSSI":100,"Signal":-44,"LinkCount":1,"Downtime":"0T00:00:03"}}
09:45:51.434 MQT: stat/tasmota/RESULT = {"POWER":"ON"}
09:45:51.438 MQT: stat/tasmota/POWER = ON
09:45:51.498 MQT: tele/tasmota/STATE = {"Time":"2021-03-21T09:45:51","Uptime":"0T00:00:09","UptimeSec":9,"Heap":28,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":19,"MqttCount":1,"POWER":"ON","Wifi":{"AP":1,"SSId":"BIOSPACE","BSSId":"C0:C9:E3:8C:64:A7","Channel":4,"RSSI":100,"Signal":-44,"LinkCount":1,"Downtime":"0T00:00:03"}}
09:45:51.522 MQT: tele/tasmota/SENSOR = {"Time":"2021-03-21T09:45:51","Switch1":"ON"}
09:46:16.576 MQT: stat/tasmota/RESULT = {"POWER":"OFF"}
09:46:16.580 MQT: stat/tasmota/POWER = OFF
09:46:16.672 MQT: stat/tasmota/RESULT = {"POWER":"ON"}
09:46:16.675 MQT: stat/tasmota/POWER = ON
09:46:16.773 MQT: stat/tasmota/RESULT = {"POWER":"OFF"}
09:46:16.776 MQT: stat/tasmota/POWER = OFF
09:46:16.926 MQT: stat/tasmota/RESULT = {"POWER":"ON"}
09:46:16.932 MQT: stat/tasmota/POWER = ON
09:46:17.180 MQT: stat/tasmota/RESULT = {"POWER":"OFF"}
09:46:17.184 MQT: stat/tasmota/POWER = OFF
09:46:17.494 MQT: stat/tasmota/RESULT = {"POWER":"ON"}
09:46:17.498 MQT: stat/tasmota/POWER = ON
09:46:17.593 MQT: stat/tasmota/RESULT = {"POWER":"OFF"}
09:46:17.597 MQT: stat/tasmota/POWER = OFF
09:46:17.642 MQT: stat/tasmota/RESULT = {"POWER":"ON"}
09:46:17.647 MQT: stat/tasmota/POWER = ON
09:46:17.845 MQT: stat/tasmota/RESULT = {"POWER":"OFF"}
09:46:17.849 MQT: stat/tasmota/POWER = OFF
