Tasmota MQTT 2 Hosts?
Is it possible to have Tasmota configured with two different IP Hosts?
Reason I am asking is that I have two instances of HA running on different devices, one is my main unit (192.168.0.63) and the other a PI2 as my Dev. (192.168.0.67)
I would like to be able to do something as in this example?
This does not work and I do not know if it is possible?
My other line of thinking is to use Domoticz but i have never delved into that…
Regards,
Mark
I have 2 instances of HA running (production and test), but my Tasmota only points to one mqtt server. Both instances of HA use the same mqtt server.
I use the Mosquitto broker from the Add-On store
this is configured on both but can only get one at once if I adjust the host IP in Tasmota.
Remove the mqtt configuration and add-on from your test-server, then re-add the mqtt integration pointing to the ip of your main unit.
I would like to be able to have the two concurrent?
You can forward messages from one mosquitto to another, but I don’t know how that is done in the add-on. With regular mosquitto it is quite easy.
http://www.steves-internet-guide.com/mosquitto-bridge-configuration/
