Not sure if this is a Tasmota or MQTT problem. I think it’s a Hassio setting.
I flashed a sonoff 4CH and a shelly1 with the tasmota firmware. Installed everything and added it to TasmoAdmin which has a connection to Mosquito mqtt.
I add an integration in Home Assistant (Configuration -> Integrations -> MQTT) and the sonoff device is added but not the shelly.
When i test mqtt (Developer Tools -> MQTT), everything works. The Shelly switches.
So everything works except it doesn’t show up in Home Assistant. I don’t think i forget a setting because the sonoff shows up. So my question is: is there another setting to get the Shelly1 (with tasmota firmware) to show up in Home Assistant
