yep. Can’t tell you how and why I got the ‘clear’ LED but it is definitely not an IR transmitter. Anyway - rule of thumb: check connections, then check the components one by one
does it work with the latest HA. I have been struggling for several days and the async_update_ha_state does not seem to be working at all. The UI card shows “Undefined” with all controls “Off”. I am running on:
Home Assistant 2022.11.2
Supervisor 2022.10.2
Operating System 9.3
Frontend 20221108.0 - latest
It works … But last 2 changes were not included, so I made a new version. You can try to update. If this does not fix the problem, post here your config for Tasmota-Irhvac.
Hi, which is the new version? I downloaded it again from here:
Used a fresh HAOS installation and followed the README. I added a new Thermostat card and here is my Dashboard config:
title: Home
- path: default_view
title: Home
cards:- type: thermostat
entity: climate.irhvac
- type: thermostat
Here is my configuration.yaml:
# Loads default set of integrations. Do not remove.
default_config:
# Load frontend themes from the themes folder
frontend:
themes: !include_dir_merge_named themes
# Text to speech
tts:
- platform: google_translate
script: !include scripts.yaml
scene: !include scenes.yaml
climate:
- platform: tasmota_irhvac
command_topic: “cmnd/irhvac_test/irhvac”
state_topic: “tele/irhvac_test/RESULT”
temperature_sensor: sensor.irhvac_test_temperature
humidity_sensor: sensor.irhvac_test_humidity
power_sensor: binaly_sensor.irhvac_test_ac_power
vendor: “MIDEA”
min_temp: 16
max_temp: 32
target_temp: 26
initial_operation_mode: “off”
away_temp: 24
precision: 1
supported_modes:- “heat”
- “cool”
- “dry”
- “fan_only”
- “auto”
- “off”
supported_fan_speeds: - “medium”
- “high”
- “min”
- “max”
supported_swing_list: - “off”
- “vertical”
default_quiet_mode: “Off”
default_turbo_mode: “Off”
default_econo_mode: “Off”
hvac_model: “-1”
celsius_mode: “On”
default_light_mode: “Off”
default_filter_mode: “Off”
default_clean_mode: “Off”
default_beep_mode: “Off”
default_sleep_mode: “-1”
default_swingv: “high”
default_swingh: “left”
keep_mode_when_off: True
toggle_list: []
And the result is like this:
Hi, I found what the root cause of the issue is. Due to lack of LWT message the MQTT marks the entity as unavailable.
Hi one question es there any way to read both state topics
state_topic: “tele/smart_ir/RESULT”
and
state_topic: “stat/smart_ir/RESULT”
beacause if i use an auotomation mqtt payload i need the stat to update climate status and if i use the remote i need the tele one to read the ir…
Thanks for your great post, everything works perfectly for me
Just one question please
How do I control light of the AC? I mean when i give commands, it took command correctly but light is off
{‘IrReceived’: {‘Protocol’: ‘FUJITSU_AC’, ‘Bits’: 128, ‘Data’: ‘0x0x1463001010FE09304013003008002025’, ‘Repeat’: 0, ‘IRHVAC’: {‘Vendor’: ‘FUJITSU_AC’, ‘Model’: 1, ‘Power’: ‘On’, ‘Mode’: ‘fan_only’, ‘Celsius’: ‘On’, ‘Temp’: 20, ‘FanSpeed’: ‘Auto’, ‘SwingV’: ‘Off’, ‘SwingH’: ‘Off’, ‘Quiet’: ‘Off’, ‘Turbo’: ‘Off’, ‘Econo’: ‘Off’, ‘Light’: ‘Off’, ‘Filter’: ‘Off’, ‘Clean’: ‘Off’, ‘Beep’: ‘Off’, ‘Sleep’: -1}}}
How do i control light to be on or off at HA
Thanks in advance
@SinanIbrahim Unfortunately, if you pass ‘Light’: ‘On’
and the light stays off, that means that the library for the IR does not support turning light on and off for your AC model.
@jbrande I’m using tele
in my config and it works for me for everywhere. If you use the climate entity in your automation it should update it in the UI too.
Hi, so I have this ir signal for controlling ceiling fan speed (low, medium, high)
18:17:43.678 MQT: tele/remote_livingroom/RESULT = {"IrReceived":{"Protocol":"SYMPHONY","Bits":12,"Data":"0xC01","DataLSB":"0x3080","Repeat":0}}
18:17:44.983 MQT: tele/remote_livingroom/RESULT = {"IrReceived":{"Protocol":"SYMPHONY","Bits":12,"Data":"0xC04","DataLSB":"0x3020","Repeat":0}}
18:17:46.088 MQT: tele/remote_livingroom/RESULT = {"IrReceived":{"Protocol":"SYMPHONY","Bits":12,"Data":"0xC43","DataLSB":"0x30C2","Repeat":0}}
How do you integrate this as fan speed entity? So I can use with this with Fan Percent Button Row (hacs)
Put this in scripts.yaml
and reload scripts or restart Home Assistant:
ir_code:
sequence:
- data_template:
payload: '{"Protocol":"{{ protocol }}","Bits": {{ bits }},"Data": {{ data }},"DataLSB":{{ lsb }},"Repeat":{{ repeat }}}'
topic: 'cmnd/remote_{{ room }}/irsend'
service: mqtt.publish
You can use it like this:
cards:
- tap_action:
action: call-service
service: script.ir_code
service_data:
bits: 12
data: 0xC01
lsb: 0x3080
repeat: 0
protocol: SYMPHONY
room: kitchen
color: white
icon: mdi:power
style:
- color: white
- background: green
- '--disabled-text-color': white
type: custom:button-card
Important: Read the very first post to understand the mqtt topic naming chema. In this example I’ve adjusted the script for your needs, but it is good idea to follow topic naming rools in order for the script to work with any of your remotes and their topics. Also the button I’ve shown uses custom button card, but you can use any card using the same action
, service
and service_data
Hi thanks, i’ve already done that
My concern was adding it to fan services in HA since i wasn’t sure how to do that
Could it update the current speed of the fan if physical remote is used? Or is fhat something that’s only limited to irhvac
It is limited to IRHVAC, there is always a way. If you make a sensor in HA, that has the value of the code from the IR receiver, you can make script or automation, that when the value of the sensor changes it performs some action. So let say if your fan has 3 speeds and their IR codes are 0x3B20
,0x3B21
,0x3B22
in the script/automation you check if the state of the sensor is with one of those 3 values and set the entity to its coresponding speed, let say min
, medium
, max
Very cool Project, but i have some understand problems
I’m using a BW-RC1 IR Controler, which is connected via tasmota.
original code:
18:09:52.612 MQT: tele/Klimaanlage_Buero_5A7A65/RESULT = {"IrReceived":{"Protocol":"PANASONIC_AC","Bits":216,"Data":"0x0220E004000000060220E00400392080320C000EE000008100008C","Repeat":0,"IRHVAC":{"Vendor":"PANASONIC_AC","Model":0,"Mode":"Cool","Power":"On","Celsius":"On","Temp":16,"FanSpeed":"Min","SwingV":"High","SwingH":"Right Max","Quiet":"Off","Turbo":"Off","Econo":"Off","Light":"Off","Filter":"Off","Clean":"Off","Beep":"Off","Sleep":-1}}}
my thermostat changes will be resume always, when i try to change it
my config.yaml is this
command_topic: "cmnd/Klimaanlage_Buero_5A7A65/irhvac"
# Pick one of the following:
# State is updated when the tasmota device receives an IR signal (includes own transmission and original remote)
# useful when a normal remote is in use alongside the tasmota device, may be less reliable than the second option.
state_topic: "tele/Klimaanlage_Buero_5A7A65/RESULT"
# State is updated when the tasmota device completes IR transmissionm, should be pretty reliable.
#state_topic: "stat/your_tasmota_device/RESULT"
# Uncomment if your 'available topic' of Tasmota IR device are different (if device in HA is disabled)
#availability_topic: "tele/your_tasmota_device/LWT"
temperature_sensor: sensor.kitchen_temperature
#humidity_sensor: sensor.kitchen_humidity #optional - default None
power_sensor: binaly_sensor.kitchen_ac_power #optional - default None
vendor: "PANASONIC_AC"
min_temp: 16 #optional - default 16 int value
max_temp: 30 #optional - default 32 int value
target_temp: 26 #optional - default 26 int value
initial_operation_mode: "off" # optional - default "off" string value (one of the "supported_modes")
away_temp: 24 #optional - default 24 int value
precision: 1 #optional - default 1 int or float value. Can be set to 1, 0.5 or 0.1
supported_modes:
- "auto"
- "heat"
- "cool"
- "dry"
- "fan_only" # Use "fan_only" even if Tasmota shows "Mode":"Fan"
- "off" #Turns the AC off - Should be in quotes
# Some devices have "auto" and "fan_only" switched
# If the following two lines are uncommented, "auto" and "fan" shoud be commented out
#- "auto_fan_only" #if remote shows fan but tasmota says auto
#- "fan_only_auto" #if remote shows auto but tasmota says fan
# Some devices say max,but it is high, and auto which is max
# If you uncomment the following two, you have to comment high and max
# - "auto_max" #woud become max
# - "max_high" #would become high
#- "on"
#- "off"
- "auto"
- "min"
- "low"
- "medium"
- "high"
- "max"
#- "off"
- "vertical" #up to down
- "horizontal" # Left to right
#- "both"
default_quiet_mode: "Off" #Quiet und Turbo sind in der Firmware vertauscht | optional - default "Off" string value
default_turbo_mode: "On" #Quiet und Turbo sind in der Firmware vertauscht | optional - default "Off" string value
default_econo_mode: "On" #optional - default "Off" string value
hvac_model: "-1" #optional - default "1" string value
celsius_mode: "On" #optional - default "On" string value
default_light_mode: "Off" #optional - default "Off" string value
default_filter_mode: "Off" #optional - default "Off" string value
default_clean_mode: "Off" #optional - default "Off" string value
default_beep_mode: "Off" #optional - default "Off" string value
default_sleep_mode: "-1" #optional - default "-1" string value
default_swingv: "high" #optional - default "" string value
default_swingh: "left" #optional - default "" string value
keep_mode_when_off: True #optional - default False boolean value : Must be True for MITSUBISHI_AC, ECOCLIM, etc.
toggle_list: #optional - default []
# The toggled property is a setting that does not retain the On state.
# Set this if your AC properties are toggle function.
- Beep
- Clean
- Econo
- Filter
- Light
- Quiet
#- Sleep
#- SwingH
#- SwingV
- Turbo
i found my issue, it was the ü,ö,ä in the Topics ^^
@gh0s7 i have some more modes as you support currently, can you add these?
- Mode: MildDry
Please add a funktion to change SwingH & SwingV in Thermostat Card
Edit:
all “default_*_mode” are not working they are always off only celsius are working any ideas?
i need to do it always manuell via services
Can a payload be sent via http cmd? I want to use Vera edge controller to send the cmd.
tasmota recognized my protocol as GOODWEATHER After setting up the config, it sends commands, but the air conditioner does not understand them.
noticed that in the commands sent by the remote there is
“Bits”:48,“Data”:“0x556A7A010000”,“DataLSB”:“0xAA565E800000”,“Repeat”:0,
by adding this to the command sent by your integration. And having sent through the console it earned.
how do i make the default integration send these commands?
remote control code example:
{“IrReceived”:{“Protocol”:“GOODWEATHER”,“Bits”:48,“Data”:“0x556A7A010000”,“DataLSB”:“0xAA565E800000”,“Repeat”:0,“IRHVAC”:{“Vendor”:“GOODWEATHER”,“Model”:-1,“Command”:“Control”,“Mode”:“Fan”,“Power”:“On”,“Celsius”:“On”,“Temp”:26,“FanSpeed”:“Min”,“SwingV”:“Off”,“SwingH”:“Off”,“Quiet”:“Off”,“Turbo”:“Off”,“Econo”:“Off”,“Light”:“Off”,“Filter”:“Off”,“Clean”:“Off”,“Beep”:“Off”,“Sleep”:-1,“iFeel”:“Off”,“SensorTemp”:“n/a”}}}
{“IrReceived”:{“Protocol”:“GOODWEATHER”,“Bits”:48,“Data”:“0x55097A010000”,“DataLSB”:“0xAA905E800000”,“Repeat”:0,“IRHVAC”:{“Vendor”:“GOODWEATHER”,“Model”:-1,“Command”:“Control”,“Mode”:“Auto”,“Power”:“On”,“Celsius”:“On”,“Temp”:25,“FanSpeed”:“Min”,“SwingV”:“Off”,“SwingH”:“Off”,“Quiet”:“Off”,“Turbo”:“Off”,“Econo”:“Off”,“Light”:“Off”,“Filter”:“Off”,“Clean”:“Off”,“Beep”:“Off”,“Sleep”:-1,“iFeel”:“Off”,“SensorTemp”:“n/a”}}}
{“IrReceived”:{“Protocol”:“GOODWEATHER”,“Bits”:48,“Data”:“0x552A1A010000”,“DataLSB”:“0xAA5458800000”,“Repeat”:0,“IRHVAC”:{“Vendor”:“GOODWEATHER”,“Model”:-1,“Command”:“Control”,“Mode”:“Cool”,“Power”:“On”,“Celsius”:“On”,“Temp”:26,“FanSpeed”:“Auto”,“SwingV”:“Off”,“SwingH”:“Off”,“Quiet”:“Off”,“Turbo”:“Off”,“Econo”:“Off”,“Light”:“Off”,“Filter”:“Off”,“Clean”:“Off”,“Beep”:“Off”,“Sleep”:-1,“iFeel”:“Off”,“SensorTemp”:“n/a”}}}
{“IrReceived”:{“Protocol”:“GOODWEATHER”,“Bits”:48,“Data”:“0x55497A010000”,“DataLSB”:“0xAA925E800000”,“Repeat”:0,“IRHVAC”:{“Vendor”:“GOODWEATHER”,“Model”:-1,“Command”:“Control”,“Mode”:“Dry”,“Power”:“On”,“Celsius”:“On”,“Temp”:25,“FanSpeed”:“Min”,“SwingV”:“Off”,“SwingH”:“Off”,“Quiet”:“Off”,“Turbo”:“Off”,“Econo”:“Off”,“Light”:“Off”,“Filter”:“Off”,“Clean”:“Off”,“Beep”:“Off”,“Sleep”:-1,“iFeel”:“Off”,“SensorTemp”:“n/a”}}}
{“IrReceived”:{“Protocol”:“GOODWEATHER”,“Bits”:48,“Data”:“0x558E3A010000”,“DataLSB”:“0xAA715C800000”,“Repeat”:0,“IRHVAC”:{“Vendor”:“GOODWEATHER”,“Model”:-1,“Command”:“Control”,“Mode”:“Heat”,“Power”:“On”,“Celsius”:“On”,“Temp”:30,“FanSpeed”:“Max”,“SwingV”:“Off”,“SwingH”:“Off”,“Quiet”:“Off”,“Turbo”:“Off”,“Econo”:“Off”,“Light”:“Off”,“Filter”:“Off”,“Clean”:“Off”,“Beep”:“Off”,“Sleep”:-1,“iFeel”:“Off”,“SensorTemp”:“n/a”}}}
{“IrReceived”:{“Protocol”:“GOODWEATHER”,“Bits”:48,“Data”:“0x558E38000000”,“DataLSB”:“0xAA711C000000”,“Repeat”:0,“IRHVAC”:{“Vendor”:“GOODWEATHER”,“Model”:-1,“Command”:“Control”,“Mode”:“Heat”,“Power”:“Off”,“Celsius”:“On”,“Temp”:30,“FanSpeed”:“Max”,“SwingV”:“Off”,“SwingH”:“Off”,“Quiet”:“Off”,“Turbo”:“Off”,“Econo”:“Off”,“Light”:“Off”,“Filter”:“Off”,“Clean”:“Off”,“Beep”:“Off”,“Sleep”:-1,“iFeel”:“Off”,“SensorTemp”:“n/a”}}}
{“IrReceived”:{“Protocol”:“GOODWEATHER”,“Bits”:48,“Data”:“0x558E3A000000”,“DataLSB”:“0xAA715C000000”,“Repeat”:0,“IRHVAC”:{“Vendor”:“GOODWEATHER”,“Model”:-1,“Command”:“Control”,“Mode”:“Heat”,“Power”:“On”,“Celsius”:“On”,“Temp”:30,“FanSpeed”:“Max”,“SwingV”:“Off”,“SwingH”:“Off”,“Quiet”:“Off”,“Turbo”:“Off”,“Econo”:“Off”,“Light”:“Off”,“Filter”:“Off”,“Clean”:“Off”,“Beep”:“Off”,“Sleep”:-1,“iFeel”:“Off”,“SensorTemp”:“n/a”}}}
{“IrReceived”:{“Protocol”:“GOODWEATHER”,“Bits”:48,“Data”:“0x55697A030000”,“DataLSB”:“0xAA965EC00000”,“Repeat”:0,“IRHVAC”:{“Vendor”:“GOODWEATHER”,“Model”:-1,“Command”:“Control”,“Mode”:“Fan”,“Power”:“On”,“Celsius”:“On”,“Temp”:25,“FanSpeed”:“Min”,“SwingV”:“Off”,“SwingH”:“Off”,“Quiet”:“Off”,“Turbo”:“Off”,“Econo”:“Off”,“Light”:“Off”,“Filter”:“Off”,“Clean”:“Off”,“Beep”:“Off”,“Sleep”:-1,“iFeel”:“Off”,“SensorTemp”:“n/a”}}}
{“IrReceived”:{“Protocol”:“GOODWEATHER”,“Bits”:48,“Data”:“0x55097A0B0100”,“DataLSB”:“0xAA905ED08000”,“Repeat”:0,“IRHVAC”:{“Vendor”:“GOODWEATHER”,“Model”:-1,“Command”:“Control”,“Mode”:“Auto”,“Power”:“On”,“Celsius”:“On”,“Temp”:25,“FanSpeed”:“Min”,“SwingV”:“Off”,“SwingH”:“Off”,“Quiet”:“Off”,“Turbo”:“Off”,“Econo”:“Off”,“Light”:“On”,“Filter”:“Off”,“Clean”:“Off”,“Beep”:“Off”,“Sleep”:-1,“iFeel”:“Off”,“SensorTemp”:“n/a”}}}
{“IrReceived”:{“Protocol”:“GOODWEATHER”,“Bits”:48,“Data”:“0x55097A0B0000”,“DataLSB”:“0xAA905ED00000”,“Repeat”:0,“IRHVAC”:{“Vendor”:“GOODWEATHER”,“Model”:-1,“Command”:“Control”,“Mode”:“Auto”,“Power”:“On”,“Celsius”:“On”,“Temp”:25,“FanSpeed”:“Min”,“SwingV”:“Off”,“SwingH”:“Off”,“Quiet”:“Off”,“Turbo”:“Off”,“Econo”:“Off”,“Light”:“Off”,“Filter”:“Off”,“Clean”:“Off”,“Beep”:“Off”,“Sleep”:-1,“iFeel”:“Off”,“SensorTemp”:“n/a”}}}
someone can tell me why (in which case) i should use “initial_operation_mode” & “power_sensor”
I dont understand these Parameters
Is there a way, to set a temp temperatur value that do not override the orginal temp on my theromstat.
is used to show if the AC as turned off or turned on after HA restart. As there is no info if the AC is turned on or off immediately after restart. power_sensor
is a sensor that can detect if AC is turned on or off. Usually some smart plug, that has power metter, but not limited to smart plugs. If there is power usage - the AC is turned on, if there isn’t or the consumption is too low - the AC is off.
I am pretty new to HA and I am trying to integrate all of my device. I just have 4 Mitsubishi Airco controlled by Tasmota IR and OpenHab and I am trying to integrate in HA.
I am able to control my Airco with HA and this addon, but I my Airco have Econo function, and I would like to add it to the card in my Dashboard. This is mi config:
climate:
command_topic: "cmnd/Tasmota-PensileCucina/IRHVAC"
state_topic: "tele/Tasmota-PensileCucina/RESULT"
temperature_sensor: sensor.xiaomi_temp_cucina_temperature #optional this sensor is used to display current temp on the AC card
protocol: "MITSUBISHI_AC"
precision: 1.0 #optional - default 1.0 float value
supported_modes:
- heat
- cool
- dry
- fan_only
- auto
- "off" #Turns the AC off - Should be quoted and should be always included here
- low
- max
- medium
- high
#- middle
#- focus
#- diffuse
- min
- auto
- "off"
- vertical #up to down
- horizontal # Left to right - remove if your AC does not support it
- both # remove if your AC does not support horizontal
default_econo_mode: "Off" #optional - default "Off" string value
hvac_model: "1" # string value
celsius_mode: "On" #optional - default "On" string value - you can remove it if you use celsius
#- Beep
#- Clean
- Econo
#- Filter
#- Light
#- Quiet
#- Sleep
#- SwingH
#- SwingV
#- Turbo
It is possible to achieve this?
