I’ve set up a Shelly1 Plus Tasmota device (on an installation with many other Tasmota device).
It used to work quite well, till I tried to configure a custom value template. I’m not sure what I did it wrong, but even after removing the custom template and restarting HA, I can’t get the Tasmota integration to show the controls (relay1) nor the sensors (swich1) entities. They have just disappeared, and I can’t find a way to debug this (I spent 3 hours trying various things w/o any success).
Shelly1 Plus is configured as follows:
SetOption19 0
SwitchMode 16
SetOption114 1
SwitchTopic extlight
GPIO4: switch_d
MQTT Full Topic is: %prefix%/%topic%/
Tasmota shows the device with the information I don’t really need
- MQTT Connect Count
- Restart Reason
- SSID
- WiFi Connect Count
but the controls and sensors are no longer visible
I can see with mosquitto_sub
that MQTT messages are sent by the device, ex.
tele/extjardin/SENSOR {"Time":"2023-01-14T20:38:02","extlight":"ON"}
tele/extjardin/SENSOR {"Time":"2023-01-14T20:38:08","extlight":"OFF"}
but Tasmota integration does not show any entities, which use to be a binary_sensor for example.
How to debug this? Thanks.
