good day
I have inputs/outputs solved with the help of ESP-01 Tasmot and expander PCF8574. Outputs are responsive with Tasmota integration. Inputs are not. I tried writing the inputs using *.yaml. They still don’t respond. Tasmoty console and MQTT explorer show that it should work:
Example: stat/TasmotaX112/RESULT = {“Time”:“2023-01-07T18:44:43”,“PCF8574-1_INP”:{“D1”:0}}
notation in *.yaml:
- name: X112_IN_00
# state_topic: "stat/TasmotaX112/RESULT"
# value_template: "{{ value_json.PCF8574-1_INP.D0 }}" # TemplateSyntaxError: expected token
# end of print statement, got _INP
state_topic: "stat/TasmotaX112/RESULT/PCF8574-1_INP"
value_template: "{{value_json.D1 }}"
availability_topic: tele/TasmotaX112/LWT
payload_available: Online
payload_not_available: Offline
I tried other notations. I guess PCF8574-1_INP → _INP bothers him ???
Thank you for your help
