Tasmota power monitoring sensors not autodiscovered
I have a Digoo DG-SP202 flashed with Tasmota 6.7.1. It has the power monitoring capability. For whatever reason, HA doesn’t automatically create mqtt sensors for it (it did for the first one I had but that died and I removed the mqtt data in the meantime).
How do I get MQTT (Mosquitto) broker to create these sensors? Or do I have to create them manually in config.yaml? MQTT Discoery is set to TRUE.
Thanks.
Are you sure you did not flash them with sonoff_basic (or tasmota_basic as it is called now) ? This version does not support autodiscovery. If you did flash them with sonoff.bin (or tasmota.bin), or after you upgraded them, do setoption19 1.
I’m fairly sure. Will try, thanks! So am I correct these sensors should be created automatically?
They should.
