I think this would be easy for an expert as I am a knob to Hass.io
I have flashed my Sonoff RF-Bridge.
Have a few door sensors and remotes and in Tasmota Console everything looks fine. I can find the codes for every sensor / button-push.
but when trying to get Hassio to see them it another storry?
I have scrolled through a lot of posts and come to the conclusion that I must do something obvious wrong?
My configuration.yaml looks like this:
“# Binary Sensors”
binary_sensor:
- platform: mqtt
state_topic: “tele/rfbridge/RESULT”
value_template: ‘{{value_json.RfReceived.Data}}’
payload_on: “5B040A”
payload_off: “5B040E”
device_class: Door
optimistic: false
qos: 1
retain: false
But I keep getting failure msg. like:
The following components and platforms could not be set up:
Please check your config."
When testing in MQTTLens and subscribing to: “tele/rfbridge/RESULT” I get following result:
“RfReceived”: {
“Sync”: 14070,
“Low”: 490,
“High”: 1370,
“Data”: “5B040E”,
“RfKey”: “None”
So my MQTT server and the RF-Bridge do see each-other and the messages are working, something is missing in my configuration.yaml, for sure.
Do the bridge itself have to be set up? I have tried a million different ways in the config but no success?
