Tihomir971
(Tihomir971)
December 10, 2020, 1:36pm
1
When I send command (turn light on/off) to Sonoff RF Bridge with Home Assistant it change status of RfRaw to On.
After that my binnary sensor (door sensor) stop working. I recive message:
MQT: tele/RF_Bridge/RESULT = {"Time":"2020-12-10T14:28:38","RfRaw":{"Data":"AAA41D5600E602BC1D08F155"}}
I have to change RfRaw to Off manually through tasmota console to work again
14:29:40 CMD: rfraw 0
14:29:40 MQT: stat/RF_Bridge/RESULT = {"RfRaw":"OFF"}
14:29:47 MQT: tele/RF_Bridge/RESULT = {"Time":"2020-12-10T14:29:47","RfReceived":{"Sync":7480,"Low":260,"High":740,"Data":"1D08F1","RfKey":"None"}}14:29:40 CMD: rfraw 0
Is there any solution to automatically turn off RfRaw?
amaximus
(Atticus Maximus)
December 10, 2020, 7:56pm
2
My scripts has something like:
reluxa_close:
alias: 'Close reluxa'
sequence:
- service: mqtt.publish
data_template:
topic: sonoffrf433/cmnd/Backlog
retain: true
payload: "RfRaw AAB035051412840618012C0302274C481A3A3A3A3A3B2A3B2A3A3B2B2A3A3B2A3A3B2A3B2A3B2B2B2B2B2A3B2A3A3A3A3A3A3B2B2A3A3B2B55"
- service: input_boolean.turn_off
entity_id: input_boolean.reluxa_open
- delay:
seconds: 1
data_template:
retain: false
payload: "RfRaw 0xA7"
however I think 0xA7 should rather be 0.
At least when the command is to be sent from Tasmota console it should be something like:
backlog rfraw AAB035051412840618012C0302274C481A3A3A3A3A3B2A3B2A3A3B2B2A3A3B2A3A3B2A3B2A3B2B2B2B2B2A3B2A3A3A3A3A3A3B2B2A3A3B2B55; rfraw 0
myle
(StePhan McKillen (Other kiwi Here))
December 10, 2020, 8:04pm
3
and here is mind
lounge_fan_1:
alias: lounge fan Speed 1
sequence:
topic: "cmnd/RF_Bridge_raw/Backlog"
payload: "RFRAW AA B0 1E 03 08 0172 02E4 2620 28090909181818180909090909090918180909091809 55 RFRAW 0"
topic: "home/lounge-fan"
payload: "1"
topic: "home/lounge/fan/cmnd/FanSpeed"
payload: "on"
mode: single
did you put the raw in the BitBucket Converter
