Tasmota SetOption114 1 bevavior in Home Assistant
Hi guys, quick question. If I detach the switch in a Shelly 1 with Tasmota using SetOption114, how is it represented in Home Assistant? Do both the switch and the relay show up as toggles? Or do I need to create template switches that toggle based on MQTT messages to get the relay and switch toggles?
