Tasmota Shelly1 as 3 way switch
Hello folks,
just tried to use a Shelly1 with Tasmota on board as 3way switch following this sketch with no fortune (the power went down):
I think that this scheme is working only with devices with the original firmware on board… Anyone can confirm?
Thanks a lot
Hi
This will also work with Tasmota Firmware if SwitchMode in Tasmota is set to 1
Have a look at the Tasmota Command Wiki, everything is well documented.
