Hi
On a tasmotat device I have a LED that I would like to turn on and off from HA.
When I set in this minimal code, I can do that
- platform: mqtt
command_topic: "cmnd/DVES_B1CF9E/LEDPOWER"
payload_on: "1"
payload_off: "0"
retain: false
I can see that i get this mqtt response:
stat/DVES_B1CF9E/RESULT = {"LedPower":"OFF"}
So I would like to use that as feedback, so I can read the actual state of the status led
- platform: mqtt
state_topic: "stat/DVES_B1CF9E/RESULT"
value_template: "{{ value_json.LEDPOWER }}"
availability_topic: "tele/DVES_B1CF9E/LWT"
qos: 1
payload_on: "ON"
payload_off: "OFF"
payload_available: "Online"
payload_not_available: "Offline"
retain: false
Unfortunatly, this does not work, as the feedback is not reconiced, and the switch in the UI, just goes back to off again after a few seconds.
How to I need to write the YAML to get this working?
