Good Morning,
I’ve got a question regarding Tasmota (Option 19 Autodiscovery: On) and Autodiscovery with Home Assistant. My Tasmota is latest Release 8.2.0 from March. Home-Assistant is 0.108.3. The Device is a ESP-01 with Binary Switch (ON/OFF) on GPIO0, configured as “Switch 1(9)”. There is another Temperature Sensor, DS18b20, on GPIO2.
On Home-Assistant side MQTT Connection is configured and running. There are several other Sensors configured on fixed topics. Autodiscovery is enabled. Enabling Autodiscovery Option 19 on Tasmota immadiately shows the device in lovelace. There are two Bullets showing up: In one hand there is the Status Button, that contains RSSI, Built, IP-Address, etc. In other hand there is the Temperature Sensor DS18b20, that shows current temp in lovelace. But the binary switch is not showing up, whatever i try to get it running.
Watching the Console on Tasmota i can see the Pin changes and sending it to telemetry topic. Can anyone help me on that?
@francisp No, Relais is defining an Output, Switch is an Binary Input.
It found out, how to get it running. Strange thing - feels like a bug! On the Tasmota MQTT Settings Page, there is a field “Topic”, with a default value. I changed this value to custom and immadiately after that change the Switch Entity appeared.
I just ran into this issue. I had a custom device that was hit by lightning. I replaced it with a new one, but reused the settings (and topic) of the old one. On Home Assistant I got no controls or sensors for this device. But as soon as I changed the topic to a new one, everything works as expected.
I do think this is a bug. My topics was always named according to the item they are controlling. Like Garagedoor or Poolpump. Now I need to change my topic naming as a workaround for this.
I just hit the same problem with replaced device. Only topic change results in switch appearing again, but what if I want to use the topic I used before? This does seem like a bug and I don’t understand why everything is detected except the switch.
UPD: The switch showed up, but it was inactive and the rest of the data disappeared. So I had to change the topic back to what it was, but switch is still disabled. I’m confused.
