Can I damage a plug or bulb by setting the wrong configuration in a template setup through TasmoAdmin.
I’ve recently flashed a selection of ESP chip based plugs using Tuya-Convert and I’ve just noticed that both avatar AWP14H plugs were not lighting the LED on the button but everything else was working OK. I’d copied the template from
So I’ve done some trial and error adjusting and now have one working, but not the other?
strange I thought as they appear identical and were bought together.
Anyway, possibly a bit late it dawned on me that I could have damaged the LED on the plug when I was changing settings. Is that possible?
