I was able to tuya convert these and put the generic Tasmota firmware on it.
Then I tried to set up Esphome by copying the template file in the link.
I replaced the details for my WiFi. I was able to compile the .yaml file and upload the firmware to the bulb.
This all went ok. It said the upload was successful. But now I cant see the bulb in my ESPhome integration or even in my WiFi network. I tried switching off and switching back on, but it didnt seem to help. I feel like it was my WiFi details that were causing the issue. I put the SSID in full caps instead of camel case by accident.
Is there a way to go back to Tasmota or the original firmware?
This is my Yaml file.
esphome:
platform: ESP8266
board: esp01_1m
wifi:
ssid: 'WIFI'
password: 'WIFIPASS'
logger:
api:
ota:
output:
- platform: esp8266_pwm
pin: GPIO4
pin: GPIO5
light:
- platform: cwww
name: "Connect CSH-GU53WW5W"
cold_white: output_daylight
warm_white: output_warm_white
cold_white_color_temperature: 6500 K
warm_white_color_temperature: 2700 K
# Ensure the light turns on by default if the physical switch is actuated.
restore_mode: ALWAYS_ON
I was able to compile the edited firmware with your suggestions.
It shows as online and I am able to add the ESPHome Integration.
However, for some reason, the entities for light are not showing up.
Could you please kindly review my updated yaml file to make sure I havent missed something else?
