Hi guys,
What setups do you use for 30+ integration points of physical switches and relays for lights? I currently use a bunch of NodeMCUs with tasmota. 5 nodemcus are sitting in the attic next to each other. I am happy with tasmota. But the nodeMCU is a bottleneck for scalability. Also, reliability suffers - for instance when 5 nodes get rebooted, one is all of a sudden is not connected. Don’t tell me this has never happened to you Pls don’t tell me to replace the node, or to increase the number of pins used on each nodeNCU to squeeze from 5 nodes to 4 or 3 [I am on a business trip now, and my daughter’s bedroom’s light wouldn’t switch on and I have no clue what happened to one of the tasmotas (this was a side note)] I am looking for an overall a more reliable solution.
Please, your opinions? PRI GPIOs?
Thank you,
