Tassmota Switch is always unavailable
Hi there,
I am trying to get a tasmota switch working under mqtt without much luck. The switch is always unavailable.
Tasmota works fine. I can toggle the switch via it’s local web page.
I have setup mqtt on it, and assigned a login/passwork.
user: mqtt_user
topic: tasmota_C0247B
This is it’s console output:
00:00:00 CFG: Loaded from flash at F9, Count 83
00:00:00 Project tasmota Tasmota Version 8.4.0(tasmota)-2_7_2_1
00:00:00 WIF: Connecting to AP1 SPACE Channel 1 BSSId 00:1D:AA:80:29:28 in mode 11N as tasmota_C0247B-1147...
00:00:01 WIF: Connected
11:51:10 HTP: Web server active on tasmota_C0247B-1147 with IP address 192.168.1.148
11:51:11 MQT: Attempting connection...
11:51:11 MQT: Connected
11:51:11 MQT: tele/tasmota_C0247B/LWT = Online (retained)
11:51:11 MQT: cmnd/tasmota_C0247B/POWER =
11:51:11 MQT: tele/tasmota_C0247B/INFO1 = {"Module":"Arlec-PC190HA","Version":"8.4.0(tasmota)","FallbackTopic":"cmnd/DVES_C0247B_fb/","GroupTopic":"cmnd/tasmotas/"}
11:51:11 MQT: tele/tasmota_C0247B/INFO2 = {"WebServerMode":"Admin","Hostname":"tasmota_C0247B-1147","IPAddress":"192.168.1.148"}
11:51:11 MQT: tele/tasmota_C0247B/INFO3 = {"RestartReason":"Software/System restart"}
11:51:11 MQT: stat/tasmota_C0247B/RESULT = {"POWER":"OFF"}
11:51:11 MQT: stat/tasmota_C0247B/POWER = OFF (retained)
11:51:15 MQT: tele/tasmota_C0247B/STATE = {"Time":"2020-08-15T11:51:15","Uptime":"0T00:00:09","UptimeSec":9,"Heap":27,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":19,"MqttCount":1,"POWER":"OFF","Wifi":{"AP":1,"SSId":"SPACE","BSSId":"00:1D:AA:80:29:28","Channel":1,"RSSI":76,"Signal":-62,"LinkCount":1,"Downtime":"0T00:00:03"}}
11:56:15 MQT: tele/tasmota_C0247B/STATE = {"Time":"2020-08-15T11:56:15","Uptime":"0T00:05:09","UptimeSec":309,"Heap":26,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":19,"MqttCount":1,"POWER":"OFF","Wifi":{"AP":1,"SSId":"SPACE","BSSId":"00:1D:AA:80:29:28","Channel":1,"RSSI":76,"Signal":-62,"LinkCount":1,"Downtime":"0T00:00:03"}}
12:01:06 APP: Serial logging disabled
12:01:15 MQT: tele/tasmota_C0247B/STATE = {"Time":"2020-08-15T12:01:15","Uptime":"0T00:10:09","UptimeSec":609,"Heap":26,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":19,"MqttCount":1,"POWER":"OFF","Wifi":{"AP":1,"SSId":"SPACE","BSSId":"00:1D:AA:80:29:28","Channel":1,"RSSI":78,"Signal":-61,"LinkCount":1,"Downtime":"0T00:00:03"}}
mqtt moquito broken is installed. With the same login/password I used on the tasmota switch.
Here is it’s config:
logins:
  - username: mqtt_user
    password: xxx
anonymous: false
customize:
  active: false
  folder: mosquitto
certfile: fullchain.pem
keyfile: privkey.pem
require_certificate: false
This is it’s log output:
[20:50:52] INFO: Setup mosquitto configuration
[20:50:52] WARNING: SSL not enabled - No valid certs found!
[20:50:52] INFO: Found local users inside config
[20:50:52] INFO: Initialize Hass.io Add-on services
[20:50:52] INFO: Initialize Home Assistant discovery
[20:50:52] INFO: Start Mosquitto daemon
1597488652: mosquitto version 1.6.3 starting
1597488652: Config loaded from /etc/mosquitto.conf.
1597488652: Loading plugin: /usr/share/mosquitto/auth-plug.so
1597488652: |-- *** auth-plug: startup
1597488652:  ├── Username/password checking enabled.
1597488652:  ├── TLS-PSK checking enabled.
1597488652:  └── Extended authentication not enabled.
1597488652: Opening ipv4 listen socket on port 1883.
1597488652: Opening ipv6 listen socket on port 1883.
1597488652: Opening websockets listen socket on port 1884.
1597488652: Warning: Mosquitto should not be run as root/administrator.
1597488653: New connection from 172.30.32.1 on port 1883.
[INFO] found homeassistant on local database
1597488654: New client connected from 172.30.32.1 as auto-17D5CD85-352F-BEA4-19DB-435A55CFC68F (p2, c1, k60, u'homeassistant').
1597488658: New connection from 192.168.1.148 on port 1883.
[INFO] found mqtt_user on local database
1597488659: New client connected from 192.168.1.148 as DVES_C0247B (p2, c1, k30, u'mqtt_user').
1597488667: Socket error on client DVES_C0247B, disconnecting.
1597488671: New connection from 192.168.1.148 on port 1883.
1597488671: New client connected from 192.168.1.148 as DVES_C0247B (p2, c1, k30, u'mqtt_user').
192.168.1.148 is the ip of my tasmota switch.
I am unsure what ip 172.30.32.1 is?? does this seem normal getting this request?
If I look at the mqtt integration, it is setup with:
NOTE: This is not from a comfig file. i copied the values from the integration Ui
broker: core-mosquitto
port: 1883
username: homeassistant
password: a very long password.
I never set these, they seemed to be auto setup for me.
and finally, I set up my switch as follows in my configuration.yaml:
switch:
   platform: mqtt
   command_topic: “cmnd/tasmota_C0247B/POWER”
   state_topic: “stat/tasmota_C0247B/POWER”
   availability_topic: “tele/tasmota_C0247B/LWT”
   qos: 1
   payload_on: “ON”
   payload_off: “OFF”
   payload_available: “Online”
   payload_not_available: “Offline”
   retain: false
I can see the entity, in the entities list -> switch.deta_pcb
but when I add it to a lovellace card. It appears but always is unavailable.
I’ve been stuck on this for hours, and have many youtube clips nd can’t seem to see what I am doing which is different to them…
Any help would be greatly appreciated.
Is this in your configuration.yaml file?
If so, remove it, restart, and set up the broker through the UI (configuration / integrations, +, mqtt)
This is the internal Home Assistant docker network. Yes it is normal.
Replace all the fancy quotes in your switch config with straight ones ". Restart and try again.
Hi Tom, no sorry, thats the fields from the UI. not the yaml file. i opied them just to show what they were…
I just added an extra bit on the end of my reply.
You’re a champion. That was it :slight_smile: :slight_smile: :slight_smile:
I so didn’t notice those wierd quotes. Musy have been copy and pasting the code.
Thank you very much
You are the boss sir.
