shabanov_av
(Andrey Shabanov)
October 29, 2021, 1:05pm
1
I need to send this string \ 0x13 \ 0x13 \ 0x00 \ 0x00 \ 0x00 \ 0x06 \ 0x01 \ 0x03 \ 0x00 \ 0x00 \ 0x00 \ 0x01 towards to the TCP sensor. Since this output did’t work I decided to send only single byte \ 0x01 for test. However, in the output from the Home Assistant server, I catched a packet in which the Payload field contains five bytes instead of one. (seen in the pictute)
How to fill the Payload field for transparently sending HEX sequence without transformation?
- platform: tcp
host: 192.168.74.48
port: 20105
timeout: 3
payload: "\0x01"
catched packet:
benny0708
(Benjamin Knoop)
February 12, 2022, 9:55am
2
Hi Andrey,
I am facing the same issue. I have to send an bytearray to the TCP sensor Did you made progress?
Regarding your query: What you can see in the output is your ascii-coded string. So it is sending the string letter by letter and not the byte 0x01. Unfortunately I have no idea how to send a “byte-wise” payload. Hopefully some have?
Ben
se3
(Sergej)
October 11, 2022, 9:53am
3
Added this feature to tcp sensor
home-assistant:dev
← se3:tcpsensor
opened 09:48AM - 11 Oct 22 UTC
You are amazing! Thanks for contributing to our project!
Please, DO N… OT DELETE ANY TEXT from this template! (unless instructed).
## Proposed change
Describe the big picture of your changes here to communicate to the
maintainers why we should accept this pull request. If it fixes a bug
or resolves a feature request, be sure to link to that issue in the
additional information section.
Added support for [HEX values in payload](https://community.home-assistant.io/t/tcp-sensor-hex-value-in-payload/351229)
## Type of change
What type of change does your PR introduce to Home Assistant?
NOTE: Please, check only 1! box!
If your PR requires multiple boxes to be checked, you'll most likely need to
split it into multiple PRs. This makes things easier and faster to code review.
Aded **payload_is_hex** boolean (default: false) flag to handle bytearray data on sender and receiver socket.
**payload_is_hex** flasg is optional, so all existing configurations are compatible and handled same way.
### Payload format if payload_is_hex set to true
**payload** format is a HEX string with space separator for better readability. see [byteaaray.fromhex](https://docs.python.org/dev/library/stdtypes.html#bytearray.fromhex) for more information.
Example:
`payload: "10 00 FF FF B6 00 00 00 C4"`
### Payload handling on socket
If **payload_is_hex** is set to **true** the socket sends and receive string data in **payload** as following:
Send:
sock.send(bytearray.fromhex(payload))
Receive:
value = " ".join("%02x" % b for b in sock.recv())
If **payload_is_hex** is set to **false** (default) the socket sends and receive string data in **payload** as following:
Send:
sock.send(payload.encode())
Receive:
value = sock.recv().decode()
### Configuration Example
Example for RS485 Wifi device [EW11](http://www.hi-flying.com/elfin-ew10-elfin-ew11):
- platform: tcp
host: 192.168.178.111
port: 8899
timeout: 10
payload_is_hex: true
value_template: "{{ value }}"
- [ ] Dependency upgrade
- [ ] Bugfix (non-breaking change which fixes an issue)
- [ ] New integration (thank you!)
- [x] New feature (which adds functionality to an existing integration)
- [ ] Deprecation (breaking change to happen in the future)
- [ ] Breaking change (fix/feature causing existing functionality to break)
- [ ] Code quality improvements to existing code or addition of tests
## Additional information
Details are important, and help maintainers processing your PR.
Please be sure to fill out additional details, if applicable.
- This PR fixes or closes issue: no issues created
- This PR is related to issue: no issues created
- Link to documentation pull request: TODO
## Checklist
Put an `x` in the boxes that apply. You can also fill these out after
creating the PR. If you're unsure about any of them, don't hesitate to ask.
We're here to help! This is simply a reminder of what we are going to look
for before merging your code.
- [x] The code change is tested and works locally.
- [x] Local tests pass. **Your PR cannot be merged unless tests pass**
- [x] There is no commented out code in this PR.
- [x] I have followed the [development checklist][dev-checklist]
- [x] The code has been formatted using Black (`black --fast homeassistant tests`)
- [ ] Tests have been added to verify that the new code works.
If user exposed functionality or configuration variables are added/changed:
TODO: add description for "payload_is_hex" optional configuration of tcp sensor.
- [ ] Documentation added/updated for [www.home-assistant.io][docs-repository]
If the code communicates with devices, web services, or third-party tools:
- [x] The [manifest file][manifest-docs] has all fields filled out correctly.
Updated and included derived files by running: `python3 -m script.hassfest`.
- [ ] New or updated dependencies have been added to `requirements_all.txt`.
Updated by running `python3 -m script.gen_requirements_all`.
- [ ] For the updated dependencies - a link to the changelog, or at minimum a diff between library versions is added to the PR description.
- [ ] Untested files have been added to `.coveragerc`.
The integration reached or maintains the following [Integration Quality Scale][quality-scale]:
The Integration Quality Scale scores an integration on the code quality
and user experience. Each level of the quality scale consists of a list
of requirements. We highly recommend getting your integration scored!
- [x] No score or internal
- [ ] 🥈 Silver
- [ ] 🥇 Gold
- [ ] 🏆 Platinum
This project is very active and we have a high turnover of pull requests.
Unfortunately, the number of incoming pull requests is higher than what our
reviewers can review and merge so there is a long backlog of pull requests
waiting for review. You can help here!
By reviewing another pull request, you will help raise the code quality of
that pull request and the final review will be faster. This way the general
pace of pull request reviews will go up and your wait time will go down.
When picking a pull request to review, try to choose one that hasn't yet
been reviewed.
Thanks for helping out!
To help with the load of incoming pull requests:
- [ ] I have reviewed two other [open pull requests][prs] in this repository.
[prs]: https://github.com/home-assistant/core/pulls?q=is%3Aopen+is%3Apr+-author%3A%40me+-draft%3Atrue+-label%3Awaiting-for-upstream+sort%3Acreated-desc+review%3Anone+-status%3Afailure
Thank you for contributing <3
Below, some useful links you could explore:
[dev-checklist]: https://developers.home-assistant.io/docs/en/development_checklist.html
[manifest-docs]: https://developers.home-assistant.io/docs/en/creating_integration_manifest.html
[quality-scale]: https://developers.home-assistant.io/docs/en/next/integration_quality_scale_index.html
[docs-repository]: https://github.com/home-assistant/home-assistant.io
Hopefully we can use it soon
