My router was suddenly discovered after I upgrade to v 0.80.0. I went on to configure it under Integrations. It is now listed under Integrations but without any unit. Also I have no entity shown under the Integration and also no entity in my list of entities connected to my router.
I get the following error message:
2018-10-14 12:25:05 ERROR (MainThread) [homeassistant.config_entries] Error setting up entry Telia WiFi-router Plus (1643RA280) for upnp
File “/usr/local/lib/python3.6/site-packages/homeassistant/config_entries.py”, line 236, in async_setup
result = await component.async_setup_entry(hass, self)
File “/usr/local/lib/python3.6/site-packages/homeassistant/components/upnp/init.py”, line 128, in async_setup_entry
await device.async_add_port_mappings(ports, local_ip=local_ip)
File “/usr/local/lib/python3.6/site-packages/homeassistant/components/upnp/device.py”, line 69, in async_add_port_mappings
internal_port)
File “/usr/local/lib/python3.6/site-packages/homeassistant/components/upnp/device.py”, line 90, in _async_add_port_mapping
lease_duration=None)
File “/usr/local/lib/python3.6/site-packages/async_upnp_client/igd.py”, line 83, in async_add_port_mapping
await action.async_call(
AttributeError: ‘NoneType’ object has no attribute ‘async_call’
What can be wrong?
