might need a variable option that we enter when setting up. If variable equals this, then look at these modals, if that, then look at these ones. Might be better than looking at a bunch and waiting for time outs or errors.
Not sure how this would work. Maybe if using modded UI or specific varients or something.
I’m moving to hass.io. Do any versions here work with it? I’m using a different version to what here as I need to log into my modem, and the version on here from memory doesn’t work with logins. I’m trying to workout how to get the version I have to work with hass.io.
Hello everybody.
Has anyone had problems with the integration?
From here I added the integration and if I did not misunderstand I added it from the integration settings. I did, it asked me for the IP of the router and since I did not find entities, I deleted the integration. Now I want to install it again and it tells me aborted. Do you think what could happen or how can I solve it? Thank you
I was using a custom component, but don’t use it anymore, and it was working fine a few months ago, but it may be broken now as that was a few versions of HA ago and I believe there have been changes to how components and integrations work.
