Tedee lock, perfect but... first alarm off then opening door
In front of our door we bought the Tedee lock, super nice little thing and works perfectly. I’ve created an automation. Door locked> alarm on. And; Lock open> Alarm off. But the lock is faster… As a result, the alarm always goes off. Is there a way to make the lock work a few seconds later (without it becoming a nuisance) or to silence the alarm faster?
I added a 5 second delay to the alarm trigger for the door with the lock. I actually don’t remember if I had an actual problem with this, I think I just added it proactively to avoid a possible scenario like you describe.
But also, how are you controlling the lock? Via it’s own app or through HA?
Hi!
I use HA for it and it’s really ideal! I get 7 entitys and that’s enough. :slight_smile:
slotje Pullspring duration
sensor.slotje_pullspring_duration
sensor.slotje_batterij
lock.slotje
binary_sensor.slotje_semi_locked
binary_sensor.slotje_pullspring_enabled
Im using the bridge and the keypat too.
Did you put the delay in the lock?
I have a simple automation that triggers my alarm system when any of a number of sensors change state. For the trigger for my door lock, I have it set for a state change of 5 seconds (instead of the default of 0s, or ANY state change).
