Device info says Firmware “154 Protocol 3”.
Also, humidity_maximum_setpoint is available…
FYI thermostats 1-4 are configured for both AIR and FLOOR. Thermostats 6 and 7 are FLOOR only. (5 is AIR only).
DIAG:
“home_assistant”: {
“installation_type”: “Home Assistant OS”,
“version”: “2025.1.4”,
“dev”: false,
“hassio”: true,
“virtualenv”: false,
“python_version”: “3.13.1”,
“docker”: true,
“arch”: “x86_64”,
“timezone”: “America/Toronto”,
“os_name”: “Linux”,
“os_version”: “6.6.73-haos”,
“supervisor”: “2024.12.3”,
“host_os”: “Home Assistant OS 14.2”,
“docker_version”: “27.2.0”,
“chassis”: “embedded”,
“run_as_root”: true
“custom_components”: {
“scheduler”: {
“documentation”: REDACTED
“version”: “v0.0.0”,
“requirements”:
“ecoplug”: {
“documentation”: REDACTED,
“version”: “1.0.0”,
“requirements”: [
“pyecoplug==0.0.5”
“reolink_dev”: {
“version”: “0.64”,
“requirements”: [
“reolink==0.0.64”,
“aiosmtpd>=1.4.2”
“tekmar_482”: {
“documentation”: “Home · WillCodeForCats/tekmar-482 Wiki · GitHub”,
“version”: “0.9.21-pre.2”,
“requirements”:
“sonoff”: {
“version”: “3.8.2”,
“requirements”: [
“pycryptodome>=3.6.6”
“watchman”: {
“version”: “0.6.5”,
“requirements”: [
“prettytable==3.12.0”
“emporia_vue”: {
“version”: “0.10.1”,
“requirements”: [
“pyemvue==0.18.6”
“sinope”: {
“documentation”: “GitHub - claudegel/sinope-gt125: Sinope custom component for Home Assistant to manage Sinopé devices directly via the GT125 gateway”,
“version”: “1.7.1”,
“requirements”: [
“crc8==0.1.0”
“hacs”: {
“version”: “2.0.5”,
“requirements”: [
“aiogithubapi>=22.10.1”
“neviweb130”: {
“version”: “2.9.3”,
“requirements”:
“integration_manifest”: {
“domain”: “tekmar_482”,
“name”: “Tekmar Gateway 482”,
“codeowners”: [
“WillCodeForCats”
“config_flow”: true,
“dependencies”: ,
“integration_type”: “hub”,
“iot_class”: “local_push”,
“issue_tracker”: REDACTED,
“loggers”: [
“custom_components.tekmar_482”
“requirements”: ,
“is_built_in”: false,
“overwrites_built_in”: false
“setup_times”: {
“null”: {
“setup”: 1.6997999992440782e-05
“01J8RDTYDTWQ9W7D0HGG3J0VTN”: {
“config_entry_setup”: 0.022571745999997006
“data”: {
“config_entry”: {
“created_at”: “2024-09-27T00:24:33.978220+00:00”,
“data”: {
“host”: “REDACTED”,
“name”: “tekmarNet”,
“port”: 3000
“discovery_keys”: {},
“disabled_by”: null,
“entry_id”: “01J8RDTYDTWQ9W7D0HGG3J0VTN”,
“minor_version”: 1,
“modified_at”: “2024-09-27T00:24:33.978223+00:00”,
“options”: {},
“pref_disable_new_entities”: false,
“pref_disable_polling”: false,
“source”: “user”,
“title”: “tekmarNet”,
“unique_id”: “REDACTED”,
“version”: 1
“gateway”: {
“fw_ver”: 154,
“pr_ver”: 3,
“reporting_state”: 1,
“setback_enable”: false
“device_3”: {
“id”: 3,
“type”: “thermostat”,
“firmware”: 121509,
“model”: “557”,
“full_name”: “Tekmarnet Thermostat 557 3”
“device_1”: {
“id”: 1,
“firmware”: 121509,
“model”: “557”,
“full_name”: “Tekmarnet Thermostat 557 1”
“device_2”: {
“id”: 2,
“firmware”: 121509,
“model”: “557”,
“full_name”: “Tekmarnet Thermostat 557 2”
“device_7”: {
“id”: 7,
“firmware”: 121509,
“model”: “557”,
“full_name”: “Tekmarnet Thermostat 557 7”
“device_4”: {
“id”: 4,
“firmware”: 121509,
“model”: “557”,
“full_name”: “Tekmarnet Thermostat 557 4”
“device_5”: {
“id”: 5,
“firmware”: 121509,
“model”: “557”,
“full_name”: “Tekmarnet Thermostat 557 5”
“device_6”: {
“id”: 6,
“firmware”: 121509,
“model”: “557”,
“full_name”: “Tekmarnet Thermostat 557 6”
“ignored”:
