Have successfully created telegram integration, confirmed by sending a “test” message through service. Afterwards created a automation to send a message after light turns on.
Are you sending to a group like home assistant alerts? If so you’ll need to add allowed_chat_ids also for the group.
In telegram do you have IDBot, BotFather, telegram and another if so thats your group.
Try following this tutorial, hes using the same polling solution. I thought I had a user account but inadvertently created a group, which does have some benefits that you can add family members to it. Telegram
And Telegram2
Also send a message to the bot in telegram create a new message and write @mybotname and send ‘hello’ , test again
Also try adding title: test, I’ve seen somewhere that it needs it.
Since you have tested the telegram bot and successful in receiving the message through the service, it wont be an issue with telegram bot. Try this automation.
- id: '1608067011813'
alias: Teste
- platform: state
entity_id: light.yeelight_office_light
to: "on"
- service: notify.telegram
message: "Luz do escritório acesa"
is it possible to create an alert for when a temperature passes x value?
Light alerts are working fine.
Now I would like to have an alert for the maximum temperature of a probe.
