I’ve just set up the telegram bot integration, and stumbled onto the fact that I cant send messages containing “not_home”.
I was trying to troubleshoot the automation for a while with help from discord, but now I’ve tested using the service-feature of the developer section.
Sending any message with “_” fails as can be seen at:
Telegram parses your text as markdown text, and then some chars will be interpreted accordingly.
What you can do, is to send messages with html as the parse_mode instead, as long as the data you sent, doesnt contain things that will be interpreted as html…
