About this blueprint
Type of blueprint: SCRIPT
What does it do?
Wait for a telegram_text
event and execute an action. Can be filtred by user_id
and chat_id
Configuration
Requirements
- Telegram Bot integration
Blueprint fields
Remove received message?: Activate this toggle to delete the received message from chat. Useful for private or secret messages (alarm codes, passwordsâŚ).
Sequence if message is received: What should happen when receiving the text message.
Sequence if message is NOT received: What should happen when NOT receiving any message.
Script variables
These variables can be set up when calling the script. See Passing variables to scripts for more information.
timeout
: Maximum time to wait for receiving a message, in seconds. Default 30 seconds. -
filter_user_id
: Execute the sequence ONLY IF the text message is received from this user_id. Leave empty to avoid filtering. -
filter_chat_id
: Execute the sequence ONLY IF the text message is received from this chat_id. Leave empty to avoid filtering.
Available variables for templating
Event data received from telegram are parsed as variables so that they are easily used in templates. These variables can be used within this automation:
telegram_text
: Text message. -
telegram_sender_first_name
: Senderâs first name. -
telegram_sender_last_name
: Senderâs last name. -
telegram_sender_full_name
: Senderâs full name, asfirst_name + " " + last_name
telegram_sender_user_id
: Senderâs user id. -
telegram_chat_id
: Chat id.
Template example
Use format {{ variable_name }}
in order to print a variable, as usual in Home Assistant.
Example: Hi {{ telegram_sender_first_name }}! You said: {{ telegram_text }}.
Related blueprints
Telegram Bot: Store a text message into an input_text entity
Telegram Bot: Respond to Telegram Command with a text message
Telegram Bot: Respond to Telegram Command by executing an action
Other blueprints
How to get this blueprint?
Click the badge to import this Blueprint (needs Home Assistant Core 2021.3 or higher):
Or you can also:
- Import this Blueprint by using the forum topic URL
- Copy-paste the content of the following frame in a new file inside your configurationâs blueprint folder:
Blueprint YAML
blueprint:
name: 'Telegram Bot: Execute an action after receiving a text message'
description: >
Wait for a `telegram_text` event and execute an action. Can be filtred by user_id and chat_id.
## Blueprint fields:
### "Remove received message?" field
### "Sequence" field
There are two sequence fields to set up (1) what should happen when receiving the text message and (2) what should happen if the text message is not received. You can use variables explained below.
## Script variables:
These variables can be set up when calling the script. See [Passing variables to scripts](https://www.home-assistant.io/integrations/script/#passing-variables-to-scripts) for more information.
- `timeout`: Maximum time to wait for receiving a message, in seconds. Default 30 seconds.
- `filter_user_id`: Execute the sequence ONLY IF the text message is received from this user_id. Leave empty to avoid filtering.
- `filter_chat_id`: Execute the sequence ONLY IF the text message is received from this chat_id. Leave empty to avoid filtering.
## Available variables in this blueprint (ONLY IF MESSAGE IS RECEIVED):
Event data received from telegram are parsed as variables so that they are easily used in templates. These variables can be used within this script:
- `telegram_text`: Text message.
- `telegram_sender_first_name`: Sender's first name.
- `telegram_sender_last_name`: Sender's last name.
- `telegram_sender_full_name`: Sender's full name, as `first_name + " " + last_name`
- `telegram_sender_user_id`: Sender's user id.
- `telegram_chat_id`: Chat id.
#### Template example
Use format `{{ variable_name }}` in order to print a variable, as usual in Home Assistant.
`Hi {{ telegram_sender_first_name }}! You said: {{ telegram_text }}.`
domain: script
input:
remove:
name: Remove received message?
description: Activate this toggle to delete the received message from chat.
default: false
selector:
boolean:
sequence_message_received:
name: Sequence if message is received
description: "What should happen when receiving a message? You can use variables explained above."
selector:
action: {}
sequence_message_failed:
name: Sequence if message is NOT received
description: "What should happen when NOT receiving any message? You can use variables explained above."
selector:
action: {}
mode: parallel
max: 10
max_exceeded: warning
fields:
timeout:
description: Maximum time to wait for receiving a message, in seconds.
default: '30'
required: true
selector:
number:
min: 0
max: 300
mode: slider
unit_of_measurement: "s"
filter_user_id:
description: Execute the sequence ONLY IF the text message is received from this user_id. Leave empty to avoid filtering.
selector:
text:
filter_chat_id:
description: Execute the sequence ONLY IF the text message is received from this chat_id. Leave empty to avoid filtering.
selector:
text:
variables:
filter_user_id: "{% if filter_user_id is defined %}{{ filter_user_id }}{% else %}{% endif %}"
filter_chat_id: "{% if filter_chat_id is defined %}{{ filter_chat_id }}{% else %}{% endif %}"
timeout: "{% if timeout is defined %}{{ timeout }}{% else %}30{% endif %}"
remove: !input remove
sequence:
- alias: "Choose whether to filter or not"
choose:
- alias: "Filter both user_id and chat_id"
conditions: "{{ filter_user_id != '' and filter_chat_id != '' }}"
sequence:
- alias: "Wait for telegram_text event"
wait_for_trigger:
- platform: event
event_type: telegram_text
event_data:
user_id: "{{ filter_user_id }}"
chat_id: "{{ filter_chat_id }}"
timeout:
seconds: "{{ timeout }}"
continue_on_timeout: true
- alias: "Filter ONLY chat_id"
conditions: "{{ filter_user_id == '' and filter_chat_id != '' }}"
sequence:
wait_for_trigger:
- platform: event
event_data:
timeout:
- alias: "Filter ONLY user_id"
conditions: "{{ filter_user_id != '' and filter_chat_id == '' }}"
sequence:
wait_for_trigger:
- platform: event
event_data:
timeout:
default:
wait_for_trigger:
- platform: event
timeout:
- alias: "Choose whether message was received or timeout completed"
choose:
- alias: "Timeout completed"
conditions: "{{ wait.trigger == none }}"
sequence: !input 'sequence_message_failed'
default:
- alias: "Message received: setting variables from trigger"
variables:
telegram_text: "{{ wait.trigger.event.data['text'] }}"
telegram_sender_first_name: "{{ wait.trigger.event.data['from_first'] }}"
telegram_sender_last_name: "{{ wait.trigger.event.data['from_last'] }}"
telegram_sender_full_name: "{{ telegram_sender_first_name }} {{ telegram_sender_last_name }}"
telegram_sender_user_id: "{{ wait.trigger.event.data['user_id'] }}"
telegram_chat_id: "{{ wait.trigger.event.data['chat_id'] }}"
telegram_message_id: "{{ wait.trigger.event.data['id'] }}"
- alias: "Execute sequence for message received"
choose:
- conditions: "{{ true }}"
sequence: !input 'sequence_message_received'
- alias: "Do I have to remove the received message from chat?"
choose:
- alias: "Yes, remove message"
conditions: "{{ remove }}"
sequence:
- alias: "Removing message"
service: telegram_bot.delete_message
message_id: "{{ telegram_message_id }}"
chat_id: "{{ telegram_chat_id }}"
Changelog
- 2022-01-30: Solved issue when not receiving any message.
- 2022-01-30: New option to remove received message.
- 2022-01-30: First version
