Hello all,
Im new with home assistant and im stuck i just wanna send /comman1 and know the temperature and humidity from my dht22 sensor. The sensor is working and i can comunicate with the bot. But i have no idea how to make the callback; any one can help me? Rpi 3 b with Home Assistant.
THANKS!!!
tom_l
November 6, 2019, 9:59pm
2
This should do it:
- id: 'telegram_dht22'
alias: 'Telegram DHT22'
platform: event
event_type: telegram_command
event_data:
data: '/comman1'
service: notify.your_telegram_notification_here
data_template:
callback_query_id: '{{ trigger.event.data.id }}'
message: " The temperature is: {{ states('sensor_your_dht22_emp_sensor_here') }}°C and the relative humidity is: {{ states('sensor_your_dht22_humid_sensor_here') }}%"
TinyDoT
November 6, 2019, 10:09pm
3
Hello bckfast877,
If you have the Telegram bot setup and communicating with HomeAssistant, then I think this is the Automation that you are looking for:
alias: 'DHT Temp and Humidity'
platform: event
event_data:
command: '/DHT'
- service: telegram_bot.send_message
data_template:
target: '{{ trigger.event.data.user_id }}'
disable_notification: true
message: "Temp - {{ states.sensor.dht_temp.state }} F \n
Humidity - {{ states.sensor.dht_humidity.state }} F \n"
So once you have this setup, in your Telegram Bot you type the command:
/DHT
You can name the the command anything you like in the automation and in the message section you have to put in your sensor info:
message: "Temp - {{ states.sensor.your_temp sensor.state }} F \n
Humidity - {{ states.sensor.your_humidity_sensor.state }} F \n"
And, this should send you the Temp and Humidity, Hope this helps.
TinyDoT
November 6, 2019, 10:10pm
4
@tom_l , dang it you beat me to it.
tom_l
November 6, 2019, 10:31pm
5
I adapted it from the famous keyboard example and the callback_query_id:
I included may not be valid.
