Telegram bot: not getting telegram_text events from groups
Hi, I have a telegram_bot set up connected to a group. I would like to be able to scan group messages for keywords, but I am not getting any telegram_text events from the group.
Whenever I send a command to the group (anything starting with /) I see a telegram_command event fire. Whenever I send just normal text to the group, I don’t get a telegram_text event. However, when I send regular text directly to the bot, I get a telegram_text event.
Does the telegram_text event only fire when talking directly to the bot?
this is my relevant telegram_bot config:
telegram_bot:
  - platform: polling
    api_key: !secret telegram_key
    allowed_chat_ids:
      - !secret telegram_id_me
      - !secret telegram_id_family_group
I was able to solve my own problem. Putting the solution here in case anyone needs it in the future.
I needed to talk to @botfather in telegram and change the privacy settings
/setprivacy - > your bot - >Disable
By default, bots are only subscribed to / commands and direct messages. Once you disable the privacy settings, they will receive all group messages.
Thanks for sharing the solution. I’m just getting started with Telegram, so I’m sure you probably have saved me some time. :wink:
