Ouwekaas
(Ouwekaas)
February 5, 2026, 3:32pm
1
Dear reader,
Thanks for reading, I try to setup “Telegram Bot” in HA and run into an error.
“Error from Telegram: httpx.UnsupportedProtocol: Request URL is missing an ‘http://’ or ‘https://’ protocol.”
I sniffed my network traffic and I can confirm, nothing has been tried to https://api.telegram.org . It really get stuck at the add on.
My API is not the real one but for lenght considurations etc…
1234567890:ABCDEFGHIJKLMNOPQRSTUVWXYZabcdefghi
Please help me.
Kind regards Ouwekaas.
juergenjw
(Jürgen W.)
February 5, 2026, 3:50pm
2
What did you configure under advanced settings?
jonathang
(Jonathan)
February 5, 2026, 4:26pm
3
Just tried doing the same and getting the same error.
advanced settings are default, so its the same as your screenshot @juergenjw
juergenjw
(Jürgen W.)
February 5, 2026, 4:41pm
4
I’m using broadcast instead of polling. And i use send message only.
Perhaps that makes a difference?
jonathang
(Jonathan)
February 5, 2026, 5:12pm
5
Polling or Broadcast give the same error message unfortunately.
sDaddy
(sDaddy)
February 5, 2026, 5:38pm
6
Have the same issue on Raspberry PI HA instance
On my second HA instance (on Mini PC) integration works perfect and I can add bot without any issues. But in second instance in Advanced settings “API endpoint” field is not displayed at all. I don’t understand why the same Telegram integration has different settings between my both HA instances
juergenjw
(Jürgen W.)
February 5, 2026, 7:15pm
7
I can reproduce the error on my HAOS 2026.2.0 where i had not installed the telegram_bot integration before.
I have the same issue on 2026.2.0
sDaddy
(sDaddy)
February 5, 2026, 7:36pm
9
to fix issue you should downgrade to previous version of HA
or recover from backup or using terminal:
ha core downgrade --version 2026.1.3
It helps me to add new telegram bot
Ouwekaas
(Ouwekaas)
February 5, 2026, 7:48pm
10
Default settings. Like shown in your picture
juergenjw
(Jürgen W.)
February 5, 2026, 7:52pm
11
This seems to be a bug that was introduced with HA 2026.2.0.
JLestis94
(Jacopo)
February 5, 2026, 7:57pm
12
Thank you. I wish developers released every three month instead of monthly.
Are both instances on 2026.2 ?
mmenzie
(MICHAEL)
February 6, 2026, 6:05pm
15
i am following this as i am getting the same error as the OP and i have the correct API key
Same problem here. Waiting for the fix…
mhenriquez
(Mauricio Henriquez)
February 7, 2026, 10:30pm
17
darn it…waiting for the fix too
agree, the only solution for now
Still had this issue on 2026.2.1
chele81
(Chele81)
February 9, 2026, 10:35pm
19
I have the same issue on Raspberry PI HA 2026.2.1
No problem with 2026.1.3
menace_dk
(dennis)
February 11, 2026, 7:28am
20
I too have the same issue on Raspberry PI HA 2026.2.1
