At the moment I’ve configured an automatic full backup on drive and on a local server, but I’d like to see if it’s possible to upload the backup on the telegram channel I’m using with home assistant.
At the moment I’ve set a manual backup on a custom path /config/SMB.
If I try to run the service with:
service: telegram_bot.send_document
file: /config/SMB/Backup.tar
Nothing is uploaded to the channel, but if I try with other files like a txt or a mp4 (small size):
file: /config/SMB/New File.txt
The file is automatically uploaded to the channel.
My backup file is around 250MB and telegram accepts files under 2GB so I don’t think that is an issue with Telegram but with the HA extension.
Is there something I’m missing or is there a limit on the size of a document on the telegram extension?
