I’m having a lot of trouble getting a telegram message to send to 2 people.
I setup a bot with my account and have an automation working using node-red.
Then added my wife’s chatid to both node-red and my config.yaml file but she isn’t receiving messages. I did message the bot from wife’s account but it seems like I’m missing some step to authorize her to use the bot?
I’ve read through the docs and searched the forums but I can’t figure out what I’m missing. Can anyone point me in the right direction?
Interesting. I recommend you to simply try to send a basic message using a command line or python client, the most simple thing you can and verify it works from there before then checking integration again with HASS.
I do this, but not with nodered.
It seems like you have the required pieces to just try it in the services section to see if it works without nodered.
If that works at least you can narrow it down.
You specifically stated you added your config to HA. This is not needed if you are using chatbot on node red. It could actually be WHY it’s not working, because you are trying to access the bot from more than one source.
Comment OUT the complete notification setup in HA config for your telegram bot. Restart node-red, and try again.
Bot in group chat with my wife, my son, myself - High priority alerts
Bot in chat with me - muted notifications - just a running log of things that happen in HA
Bot in chat with my son - Alerts intended just for him
Bot in chat with my wife - Alerts intended just for her
All of these are created with only ONE bot and messages are all sent through Node Red Chatbot
Mine is kind of similar.
One bot, many chats.
One chat for snapshots when cameras are triggered for husband and I.
One chat for things I need to access later - for instance, if I am in my office and want to use a recipe I found, I send it to a different chat so I can access it from the kitchen tablet.
One for my kids stuff, etc
