Telegram integration: Add support for multiple bots
As already discussed here there is obviously a need for multiple telegram bots to be used within a single HA instance.
So in summary this is the feature request:
Add support for multiple telegram bots within a single HA Telegram integration.
Thanks!
I also have the need for this! I am coming from OpenHab and it was no problem to have multiple bots there. For example one bot for the washing mashine, one for the dryer, one for information… It’s just way more readable and clear :slight_smile:
It would be really great to have this. Thank you in advance!
+1 on this, I would like to have a “Window Bot”, a “Door Bot”, a “Light Bot”, a “Battery Bot” and so on, all with different Icons…
I would also like to add a +1 on it. Migrating from openHAB at the moment and I do use two Telegram bots there. One for notifications and one for alerts. I would like to continue like this, as notifications and alerts have different sounds on the phone for example.
Fix here: Fix send telegram notification to multiple chats by saippuakauppias · Pull Request #144922 · home-assistant/core · GitHub
This feature has been added in PR 144617. You can create multiple bots in the UI. There’s also a new Config entry field for the service actions (e.g. send message) to allow you to select which bot you want to use to perform the action.
You can learn more from the preview docs.
