Hello, anyone knows if the Telegram integration needs to be installed, or if dependencies need some sort of update?
(Home Assistant Supervised)
I am getting and error:
The following integrations and platforms could not be set up:
telegram_bot
telegram.notify
I can´t search the services on the Developer Tools neither.
When I check the HA log get this errors:
Logger: homeassistant.components.telegram_bot
Source: components/telegram_bot/__init__.py:422
Integration: telegram_bot (documentation, issues)
First occurred: 12:23:17 AM (1 occurrences)
Last logged: 12:23:17 AM
Error setting up platform polling
File "/usr/src/homeassistant/homeassistant/components/telegram_bot/__init__.py", line 316, in async_setup
receiver_service = await platform.async_setup_platform(hass, p_config)
File "/usr/src/homeassistant/homeassistant/components/telegram_bot/polling.py", line 18, in async_setup_platform
bot = initialize_bot(config)
File "/usr/src/homeassistant/homeassistant/components/telegram_bot/__init__.py", line 422, in initialize_bot
return Bot(token=api_key, request=request)
File "/usr/local/lib/python3.9/site-packages/telegram/bot.py", line 206, in __init__
self.token = self._validate_token(token)
File "/usr/local/lib/python3.9/site-packages/telegram/bot.py", line 300, in _validate_token
raise InvalidToken()
telegram.error.InvalidToken: Invalid token
Logger: homeassistant.setup
Source: setup.py:154
Setup failed for telegram_bot: Integration failed to initialize.
Source: setup.py:289
First occurred: 12:23:18 AM (1 occurrences)
Last logged: 12:23:18 AM
Unable to prepare setup for platform telegram.notify: (DependencyError(...), 'Could not setup dependencies: telegram_bot')
