Telegram mqtt
I need to connect my telegram bot with my local MQTT.
The idea is, when I send from my phone some message to my bot , MQTT to have this massage and do some automation based on the “command” ,which have from telegram.
Is there any way to do that?
No need for the mqtt broker.
You can do actionable messages direct from Telegram to Home Assistant.
I don’t see any info here:
Telegram - Home Assistant (home-assistant.io)
can you point me some guide, please ?
No need. Found it !
Thank you!
This post has a lot of hints:
