Telegram Not Working With Multiple Alerts
I just started with Telegram, I’m using it to notify me when a door sensor is left open. In testing it with one for the doors it works as expected, however, when I test it against another door it will not send the notification.
below is my configuration, I’m on hassbian 0.52.1
telegram_bot:
  - platform: polling
    api_key: API KEY
    allowed_chat_ids:
      - ChatBotID_1
notify:
  - name: Telegram
    platform: telegram
    chat_id: ChatBotID_1
alert:
  yard_door:
    name: The yard door is open
    done_message: The yard door is open
    entity_id: binary_sensor.rear_yard_door_opened
    state: 'on'
    repeat: 1
    can_acknowledge: True
    skip_first: False
    notifiers:
      - Telegram
alert 2:
  garage_door:
    name: The garage door is open
    done_message: The the garage door is open
    entity_id: binary_sensor.garage_door_entrance_opened
    state: 'on'
    repeat: 1
    skip_first: False
    notifiers:
      - Telegram
The yard_door alert works perfectly but the garage_door doesn’t send the alert to telegram, the sensor is working as I can see it go from “closed” to “open”. I tested this setup under with Pushbullet and it works fine.
What am I doing wrong?
I figured it out, you only need to call the alert one time and place and place all of the alerts you need below it. There may be an easier method but this one worked for me.
alert:
  yard_door:
    done_message: The yard door was closed
    state: 'on'
    repeat: 1
    skip_first: False
    notifiers:
      - Telegram
  garage_door:
    done_message: The garage door was closed
    state: 'on'
    repeat: 1
    skip_first: False
    notifiers:
      - Telegram
Hope this helps someone else.
Additionally, if you want to do group chat so that several people receive the same alert create the group, add the people you want including the bot you created for the alerts. Now go to https://web.telegram.org, next go to the group you created, look at the URL, copy the numbers after =g (https://web.telegram.org/#/im?p=g103143636), add a - to those numbers (-103143636) and set it as one of your allowed chat ids.
