Hi there, I am trying to create an automation to notify the start of irrigation
- alias: 'Sprinkler notification'
- platform: state
entity_id:
- switch.zone_4
- switch.zone_3
- switch.zone_2
- switch.zone_1
to: 'on'
service: notify.home
data_template:
message: '{{ trigger.entity_id }}'
unfortunately it works with
message: "Sprinkler on"
but it doesn’t work with data_template to select an entity_id.
thanks in advance
Try this:
{{ trigger.to_state.entity_id }}
I have tried without success
- platform: state
entity_id:
- switch.zona_4
- switch.zona_3
- switch.zona_2
- switch.zona_1
to: 'on'
data_template:
message: '{{ trigger.to_state.entity_id }}'
any other suggestions?
What message do you get or do you get no message at all?
I noticed once it was switch.zone_1
and now it’s switch.zona_1
, please make sure that it’s the correct entity id
No message at all.
Entity is correct, zone was a previous version
What kind of notifier is notify.home?
Do you get a notification if you change the action to:
service: persistent_notification.create
data_template:
This work.
“notify.home” sends a telegram message, but I can’t understand why it shouldn’t work, I already use “notify.home” for other notifications that work properly
I did a test with another automation and {{trigger.entity_id}} does not work with notification via Telegram but works correctly with persistent_notification.create.
Probably some Telegram bot setting?
is this notify.home a notification group or just one notifier?
SOLVED
Fixed, the problem was Telegram. I changed the service and set the parse_mode: html
- platform: state
entity_id:
- switch.zona_4
- switch.zona_3
- switch.zona_2
- switch.zona_1
to: 'on'
- service: telegram_bot.send_message
data_template:
target: YOUR CHAT ID
parse_mode: html
message: "Sprinkler on in zone {{ trigger.to_state.entity_id.split('_')[1] }}"
thank you very much
