I am running the following setup:
Proxmox 8.2.4
Home Assistant 2024.7.1 (is running in its own container)
Node-Red v4.0.2, Mosquitto, MariaDB (are running in a separate container)
Frigate 0.13.2 (with Google usb coral TPU) (is also running in it own container)
All is working. But I am receiving a lot of false positives (may alarm messages in Telegram) are not correct.
Within Frigate, I excluded areas where I don’t want to receive detection alerts from, and person detection above 70%.
How can I make the alerts in Telegram the same as within Frigate/ or reduce them:
- person detection above 70%
- only alert if person, dog, and cats are detected in certain areas
- only alerts when I am not at home
Hopefully someone can help out?
Kind regards,
Robert
I tried editing the following script, but nothing worked for me.
blueprint:
name: Frigate - Telegram Notification
description: Create automations to receive Snapshots and Clips from Frigate
domain: automation
input:
camera:
description: The name of the camera as defined in your frigate configuration (/conf.yml).
target_chat:
description: 'The chat_id to be used by the Telegram bot.
!secret chat_id is not allowed on Blueprint, you will need the chat_id code.
notification:
description: 'Select "true" to disable notification, lave "false" to receive
notification.
selector:
select:
options:
- 'true'
- 'false'
default: 'false'
base_url:
name: (Optional) Base URL
description: The external url for your Home Assistant instance. This will default
to a relative URL and will open the clips in the app instead of the browser,
which may cause issues on some devices.
default: ''
zone_filter:
name: (Optional) Zone Filter
description: Only notify if object has entered a defined zone.
default: false
selector:
boolean: {}
zones:
name: (Optional) Trigger Zones
description: A list (-) of zones you wish to recieve notifications for.
default:
- frigate/oprit_yard,
- frigate/voortuin_yard,
- frigate/achtertuin_yard
selector:
object: {}
labels:
name: (Optional) Trigger Objects
description: A list (-) of objects you wish to recieve notifications for.
default: []
selector:
object: {}
presence_filter:
name: (Optional) Presence Filter
description: Only notify if selected presence entity is not "home".
default: ''
selector:
entity: { }
source_url: https://gist.github.com/NdR91/5486a1e55101e062c48545395b7dd9a3
mode: single
max_exceeded: silent
platform: mqtt
topic: frigate/events
payload: !input 'camera'
value_template: '{{ value_json[''after''][''camera''] }}'
variables:
id: '{{ trigger.payload_json[''after''][''id''] }}'
camera: '{{ trigger.payload_json[''after''][''camera''] }}'
camera_name: '{{ camera | replace(''_'', '' '') | title }}'
target_chat: !input 'target_chat'
object: '{{ trigger.payload_json[''after''][''label''] }}'
label: '{{ object | title }}'
entered_zones: '{{ trigger.payload_json[''after''][''entered_zones''] }}'
type: '{{ trigger.payload_json[''type''] }}'
base_url: !input 'base_url'
zone_only: !input 'zone_filter'
input_zones: !input 'zones'
zones: '{{ input_zones | list }}'
input_labels: !input 'labels'
labels: '{{ input_labels | list }}'
presence_entity: !input 'presence_filter'
notification: !input 'notification'
condition:
- '{{ type != ''end'' }}'
- '{{ not zone_only or entered_zones|length > 0 }}'
- '{{ not zones|length or zones|select(''in'', entered_zones)|list|length > 0 }}'
- '{{ not labels|length or object in labels }}'
- '{{ not presence_entity or not is_state(presence_entity, ''home'') }}'
- service: telegram_bot.send_photo
target: '{{ target_chat }}'
disable_notification: '{{ notification }}'
caption: |
Motion detected. Camera: {{ camera_name }} (ID: {{ id }})
url: >-
{{base_url}}/api/frigate/notifications/{{id}}/snapshot.jpg?bbox=1
- repeat:
sequence:
- wait_for_trigger:
- platform: mqtt
payload: '{{ id }}'
value_template: '{{ value_json[''after''][''id''] }}'
timeout:
minutes: 2
continue_on_timeout: false
- condition: template
#value_template: '{{ wait.trigger.payload_json[''type''] == ''end'' }}'
value_template: '{{ wait.trigger.payload_json[''type''] == ''new'' }}'
- service: telegram_bot.send_video
caption: 'Motion detected: {{ camera_name }}'
url: >-
{{base_url}}/api/frigate/notifications/{{id}}/{{camera}}/clip.mp4
until: '{{ wait.trigger.payload_json[''type''] == ''end'' }}'
