I have upgraded my HA to version 0.43.1 and I notice all notifications via Telegram has stopped working.
Anyone else experiencing this?
Yes, my problem is same. Also
platform: event
event_type: homeassistant_start
stopped working too.
Back to 0.43.0
sudo pip3 install --upgrade homeassistant==0.43.0
Downgraded to 0.43.0 still doesnât work. It was working but not sure why is has stopped working.
I see this in the logâŚ
ERROR (MainThread) [homeassistant.components.notify] Error setting up platform telegram
File "/usr/local/lib/python3.4/dist-packages/homeassistant/components/notify/__init__.py", line 101, in async_setup_platform
None, platform.get_service, hass, p_config, discovery_info)
File "/usr/lib/python3.4/asyncio/futures.py", line 388, in __iter__
yield self # This tells Task to wait for completion.
File "/usr/lib/python3.4/asyncio/tasks.py", line 286, in _wakeup
value = future.result()
File "/usr/lib/python3.4/asyncio/futures.py", line 277, in result
raise self._exception
File "/usr/lib/python3.4/concurrent/futures/thread.py", line 54, in run
File "/usr/local/lib/python3.4/dist-packages/homeassistant/components/notify/telegram.py", line 49, in get_service
username = bot.getMe()['username']
File "/home/pi/.homeassistant/deps/telegram/bot.py", line 125, in decorator
result = func(self, *args, **kwargs)
File "/home/pi/.homeassistant/deps/telegram/bot.py", line 174, in getMe
result = self._request.get(url)
File "/home/pi/.homeassistant/deps/telegram/utils/request.py", line 170, in get
result = self._request_wrapper('GET', url)
File "/home/pi/.homeassistant/deps/telegram/utils/request.py", line 132, in _request_wrapper
resp = self._con_pool.request(*args, **kwargs)
File "/home/pi/.homeassistant/deps/urllib3/request.py", line 66, in request
**urlopen_kw)
File "/home/pi/.homeassistant/deps/urllib3/request.py", line 87, in request_encode_url
return self.urlopen(method, url, **extra_kw)
File "/home/pi/.homeassistant/deps/urllib3/poolmanager.py", line 303, in urlopen
conn = self.connection_from_host(u.host, port=u.port, scheme=u.scheme)
File "/home/pi/.homeassistant/deps/urllib3/poolmanager.py", line 219, in connection_from_host
return self.connection_from_context(request_context)
File "/home/pi/.homeassistant/deps/urllib3/poolmanager.py", line 232, in connection_from_context
return self.connection_from_pool_key(pool_key, request_context=request_context)
File "/home/pi/.homeassistant/deps/urllib3/poolmanager.py", line 245, in connection_from_pool_key
pool = self.pools.get(pool_key)
File "/usr/lib/python3.4/_collections_abc.py", line 425, in get
return self[key]
File "/home/pi/.homeassistant/deps/urllib3/_collections.py", line 53, in __getitem__
item = self._container.pop(key)
File "/usr/lib/python3.4/collections/__init__.py", line 178, in pop
if key in self:
TypeError: unhashable type: 'list'
The issue here is that urllib3
has been upgraded to 1.21 which causes issues with python-telegram-bot
. Downgrading to urllib
1.20 resolves this issue for now. There doesnât seem to be a hard dependency for this version in either HA or the telegram lib.
This fixed it for me:
sudo pip3 install urllib3==1.20
I have sudo pip3 install urllib3==1.20
but the problem is still not fixed.
Did you restart HA afterwards?
restarted and rebooted
thanks. but how do I apply the fix?
Check out my latest comment on the issue
If you have a virtualenv in /home/hass
use the line below
~/bin/pip3 install urllib3==1.20 --upgrade --target /home/hass/.homeassistant/deps/
im not using virtualenv. I just install HA using sudo pip3 install homeassistant
Then sudo
to the hass user and do:
pip3 install urllib3==1.20 --upgrade --target ~/.homeassistant/deps/
The urllib3 installation that is used by hass is in the deps folder.
thanks. it works!
hi @kirichkov HA is running on windows⌠will you please tell me how can i fix this issue on windows?
my /deps/ directory looks like this âC:\Users\mohammed\AppData\Roaming.homeassistant\depsâ
Iâm sorry but I never used python on windows so I have no idea how this would work. If you have pip3 in your PATH, then this should theoretically fix it. TRY IT AT YOUR OWN RISK!:
pip3 install urllib3==1.20 --upgrade --target "C:\Users\mohammed\AppData\Roaming.homeassistant\deps"
it successfully installed still I get an error when I restart
C:\Users\mohammed>pip3 install urllib3==1.20 --upgrade --target C:\Users\mohammed\AppData\Roaming.homeassistant\deps
Collecting urllib3==1.20
Using cached urllib3-1.20-py2.py3-none-any.whl
Installing collected packages: urllib3
Successfully installed urllib3-1.20
this fix supposed to work for both telegram notification and webhook?
Perfect thanks! It worked great.
I run hass in VirtualEnv and all I did was:
sudo su -s /bin/bash hass
(my HA user is called hass not homeassistant)
Then I ran this to activate the VirtualEnv:
source /srv/hass/bin/activate
The finally this (as above) to install the correct version:
Quick restart of the HA service and I now get notifications when my iKettle boils again !
