Since I installed the latest HASS version I notice the telegram notification often doesn’t work and these are the errors:
17-02-10 23:10:55 ERROR (Thread-5) [homeassistant.components.notify.telegram] Error sending message
File "/home/homeassistant/.homeassistant/deps/urllib3/connectionpool.py", line 600, in urlopen
chunked=chunked)
File "/home/homeassistant/.homeassistant/deps/urllib3/connectionpool.py", line 386, in _make_request
six.raise_from(e, None)
File "<string>", line 2, in raise_from
File "/home/homeassistant/.homeassistant/deps/urllib3/connectionpool.py", line 382, in _make_request
httplib_response = conn.getresponse()
File "/usr/lib/python3.4/http/client.py", line 1172, in getresponse
response.begin()
File "/usr/lib/python3.4/http/client.py", line 351, in begin
version, status, reason = self._read_status()
File "/usr/lib/python3.4/http/client.py", line 313, in _read_status
line = str(self.fp.readline(_MAXLINE + 1), "iso-8859-1")
File "/usr/lib/python3.4/socket.py", line 371, in readinto
return self._sock.recv_into(b)
File "/usr/lib/python3.4/ssl.py", line 745, in recv_into
return self.read(nbytes, buffer)
File "/usr/lib/python3.4/ssl.py", line 617, in read
v = self._sslobj.read(len, buffer)
ConnectionResetError: [Errno 104] Connection reset by peer
File "/home/homeassistant/.homeassistant/deps/telegram/utils/request.py", line 132, in _request_wrapper
resp = self._con_pool.request(*args, **kwargs)
File "/home/homeassistant/.homeassistant/deps/urllib3/request.py", line 70, in request
**urlopen_kw)
File "/home/homeassistant/.homeassistant/deps/urllib3/request.py", line 148, in request_encode_body
return self.urlopen(method, url, **extra_kw)
File "/home/homeassistant/.homeassistant/deps/urllib3/poolmanager.py", line 244, in urlopen
response = conn.urlopen(method, u.request_uri, **kw)
File "/home/homeassistant/.homeassistant/deps/urllib3/connectionpool.py", line 649, in urlopen
_stacktrace=sys.exc_info()[2])
File "/home/homeassistant/.homeassistant/deps/urllib3/util/retry.py", line 347, in increment
raise six.reraise(type(error), error, _stacktrace)
File "/home/homeassistant/.homeassistant/deps/urllib3/packages/six.py", line 685, in reraise
raise value.with_traceback(tb)
chunked=chunked)
response.begin()
urllib3.exceptions.ProtocolError: ('Connection aborted.', ConnectionResetError(104, 'Connection reset by peer'))
File "/srv/homeassistant/lib/python3.4/site-packages/homeassistant/components/notify/telegram.py", line 122, in send_message
parse_mode=parse_mode)
File "/home/homeassistant/.homeassistant/deps/telegram/bot.py", line 125, in decorator
result = func(self, *args, **kwargs)
File "/home/homeassistant/.homeassistant/deps/telegram/bot.py", line 151, in decorator
result = self._request.post(url, data, timeout=kwargs.get('timeout'))
File "/home/homeassistant/.homeassistant/deps/telegram/utils/request.py", line 207, in post
**urlopen_kwargs)
File "/home/homeassistant/.homeassistant/deps/telegram/utils/request.py", line 138, in _request_wrapper
raise NetworkError('urllib3 HTTPError {0}'.format(error))
telegram.error.NetworkError: urllib3 HTTPError ('Connection aborted.', ConnectionResetError(104, 'Connection reset by peer'))
Any idea what it might be?
