Posted this in the 0.80 release, but maybe someone has had this issue before.
My Telegram notifications are not working since updating from 0.79.3, getting this in the log:
Retrying (Retry(total=1, connect=None, read=None, redirect=None)) after connection broken by ‘NewConnectionError(’<telegram.vendor.ptb_urllib3.urllib3.connection.VerifiedHTTPSConnection object at 0x7f8a35cb09e8>: Failed to establish a new connection: [Errno -3] Try again’,)’: /botMYAPIKEY/getUpdates
I rolled back to a VM snapshot with 0.77.3, notifications started working again, then after a few hours without me changing anything at all, they once again stopped. What could be the reason?
I’ve been getting a few errors on a Telegram node on node-red so may not be a Home Assistant issue. Not 100% failure but not reliable either in the last few weeks.
Thu Oct 18 2018 12:25:49 GMT+0200 (Central European Summer Time)
Retrying (Retry(total=1, connect=None, read=None, redirect=None)) after connection broken by ‘NewConnectionError(’<telegram.vendor.ptb_urllib3.urllib3.connection.VerifiedHTTPSConnection object at 0x7053f170>: Failed to establish a new connection: [Errno -3] Try again’,)’: /bot0123456789:APIKEY/getUpdates
After a reinstall and 3 days of working normally, the notifications stopped again, I noticed that after my last received notification and before the latest one that I should have received, these errors started popping up in components/http/ban.py:
Login attempt or request with invalid authentication from 192.168.1.1
Are you guys using the polling method or the other one for Telegram notifications? Maybe the constant polling is getting the bot banned from my network now…?
Seems like it was a false alarm this time, I didn’t get the notification because the door sensor in question had previously remained in the “on” position, triggering 2 notifications then and none now…still, I’d be curious if our errors are related to polling or the other method as well. Anyone else?
Are there any updates ? I continue to see that error while using the polling…
And if I use ‘webhooks’, notifications works well but the bot ignore my command (sent by the chat)
I am beginning to get the following error, it still seems to work though:
Retrying (Retry(total=2, connect=None, read=None, redirect=None)) after connection broken by ‘NewConnectionError(’<telegram.vendor.ptb_urllib3.urllib3.connection.VerifiedHTTPSConnection object at “some ID”;: Failed to establish a new connection: [Errno 101] Network unreachable’,)’: /bot"someID"/getUpdates
Anyone getting something similar? I get the error in the logs like every 10 minutes.
