I had high hopes for your suggestion as it made plausible sense given that the examples here https://home-assistant.io/components/notify.telegram/ are in Caps, but unfortunately this didn’t help me in the end as it still gives the same error.
Yeah, changed to capitals but didn’t work unfortunately. The only difference between yours and mine was the title line, so I removed it but that didn’t help either. Very odd indeed. Are you using Hass.io?
The error message always appears in lowercase despite the name being in uppercase:
WARNING (MainThread) [homeassistant.core] Unable to find service nofity/telegramme
I’m going to fire up a non-hass.io HA install on a spare Pi to see if that helps.
So then, something wrong with my yaml perhaps. I’ll strip everything out and just leave a bare bones telegram setup to see if that helps. Thanks for the tip!
It’s not solved yet - it worked using developer tool but still doesn’t work using yaml. I’m trying a few options out at the moment so hopefully will have it solved soon.
Now it’s solved!! Phew, got there in the end, thank you @pembo
Once I was able to confirm functionality with the developer tool I knew it had to be my yaml, so taking the script example you gave above I was able to work the following into my first example:
Hi, I also have a mistake similar to yours. I have enabled many chat_id but only for 3 of them in the blog I see the error “unable to find service notify.xxxx”
