Telegram send jpg not working after migration from RP3 to NUC
Yesterday i did a fresh install of Hass.io on a Intel NUC and transfered my config files from Pi3 to NUC. Everything is working accept sending JPG file with telegram. Messages without a JPG work fine.
The following errors appear in the logging: (all sensitive data removed)
  • Can’t send file with kwargs: {‘message’: ‘nietbelangrijk’, ‘url’: ‘’, ‘caption’: '*’}
    and
  • Can’t load photo into ByteIO: HTTPSConnectionPool(host=’*******’, port=8123): Max retries exceeded with url: ******** (Caused by ConnectTimeoutError(<urllib3.connection.VerifiedHTTPSConnection object at 0x7f3c76ba6a90>, ‘Connection to ********* timed out. (connect timeout=15)’))
Everything else is working fine… Ive got no idea where to go from here…
Nothing? Still can’t find the problem…
Did you solve the Problem, because I have got the same error message?
