Telegram send video file (Ring)
i’m trying to let ha. send a video to my telegram channel but i’m always greeted with an error:
Can't send file with kwargs: {'message': 'Last Ring Video', 'file': 'test.mp4'}
2:41 PM components/telegram_bot/__init__.py (ERROR)
'test.mp4' are not secure to load data from!
2:41 PM components/telegram_bot/__init__.py (WARNING
this is my config:
- id: ring_video_download
  alias: Ring Video Download
  hide_entity: true
  - entity_id: binary_sensor.ring_front_door_motion
    to: 'on'
    platform: state
  condition: []
  - service: downloader.download_file
    data_template:
      url: '{{ states.camera.front_door.attributes.video_url }}'
      filename: test.mp4
      overwrite: true
  - service: notify.oneplus
      message: Last Ring Video
        video:
        - file: test.mp4
i also added this to my configuration:
  download_dir: /share
python_script:
  whitelist_external_dirs:
    - /share
can anyone spot an error ?!?
Did you come right with this? @jeroen.nijssen I’m trying to do the same, just wondering if I need to carry on searching. :slight_smile:
Howdy!
So got this all working nicely. :slight_smile: Just trying to figure out how long it takes for my doorbell to upload to ring, then making it accessible to home assistant. 1 minute seems too short, but for you it may be perfect. YMMV. Just a case of fiddling with the delay in these automation scripts.
In your config yaml file, don’t forget to add two things.
First, inside your main homeassistant setup :
homeassistant:
  auth_providers: []
  allowlist_external_dirs:
    - /config/www/images/
    - /downloads/
    - /downloads/
Then anywhere you like in your config file, allow the downloader component and specify where this downloads to. [Pro-tip: map it to somehting that isn’t your SD card]
downloader:
  download_dir: /downloads
First one is a motion detection script:
- alias: Telegram notification -Front door motion
  - entity_id: binary_sensor.front_door_motion
    platform: state
    to: 'on'
  - service: notify.Bergen_telegram
    data_template:
      message: "Movement detected at the Front Door. I'll send a photo in a bit. You know how slow Ring is."
  - delay: 00:02:00
  - service: camera.snapshot
      entity_id: camera.front_door_2
      filename: /downloads/ring/fdoor-snapshot.jpg #/config/www/images/fdoor-snapshot.jpg
  - service: telegram_bot.send_photo
    data_template:
      file: /downloads/ring/fdoor-snapshot.jpg #/config/www/images/fdoor-snapshot.jpg
      caption: The perp
      target: []
      disable_notification: true
      timeout: 1000
    data_template:
      url: "{{ states.camera.front_door_2.attributes.video_url }}"
      subdir: ring
      filename: fdoor_latest.mp4
      overwrite: true
  - delay: 00:00:05
  - service: telegram_bot.send_video
      file: /downloads/ring/fdoor_latest.mp4
      caption: Here's the video from Ring
      target: []
      timeout: 1000
      inline_keyboard:
      - Show options:/options
This second one is is a call & command request script - type in /frontdoor_vid in telegram (or add to your options menu) and back comes the last video that was recorded by ring for that device:
- alias: Request Ring Video Download
  - event_type: telegram_callback
    event_data:
      data: /frontdoor_vid
    platform: event
  - event_type: telegram_command
    event_data:
      command: /frontdoor_vid
    platform: event
  condition: []
    data_template:
      subdir: ring
      overwrite: true
  - delay: 00:00:05
      target: []
      callback_query_id: '{{ trigger.event.data.id }}'
      caption: Latest front door video from Ring
      timeout: 1000
      inline_keyboard:
Hopefully that helps someone other than me. :slight_smile:
Hi there,
following your example, however seems can’t save jpg on the path, only the mp4.
homeassistant.log error
configuration.yaml
  auth_providers: []
    - /config/downloads
    - /config/downloads/ring
    - /config/downloads
automation.yaml
- id: '1608067011823'
  - entity_id: binary_sensor.front_door_exterior_ding
    platform: state
    to: 'on'
  - service: notify.telegram
    data_template:
  - delay: 00:02:00
      entity_id: camera.front_door_exterior
      filename: /config/downloads/ring/fdoor-snapshot.jpg
    data_template:
      file: /config/downloads/ring/fdoor-snapshot.jpg
      caption: The perp
      target: []
      timeout: 1000
    data_template:
      url: "{{ states.camera.front_door_exterior.attributes.video_url }}"
      subdir: ring
      overwrite: true
  - delay: 00:00:05
      file: /config/downloads/ring/fdoor_latest.mp4
      target: []
      timeout: 1000
      inline_keyboard:
any ideas on what’s missing?
Any suggestion how to sort this out?
This stuff is not accepted in configuration.yaml and I am not able to make it work.
Anyone who fixed this?
I have a code which works now:
alias: "Sicherheit: Türklingel Video speichern"
  - platform: state
    entity_id:
      - binary_sensor.haustur_ding
    to: "on"
  - service: telegram_bot.send_message
      message: Bewegung an der Haustür detektiert! Bild folgt...
  - delay: "00:02:00"
    enabled: true
      filename: www/downloads/ring/haustuer_snapshot.jpg
      entity_id: camera.haustur
      file: www/downloads/ring/haustuer_snapshot.jpg
      caption: Ring
    data_template:
      url: "{{ states.camera.haustur.attributes.video_url }}"
      subdir: ring
      filename: haustuer_video.mp4
      overwrite: true
  - delay: "00:00:05"
    enabled: true
      file: www/downloads/ring/haustuer_video.mp4
      caption: Hier ist das Video dazu.
The only problem I have is the video format which is square and not 16:9 like the video source.
I have the same problem, were you able to resolve it? Actually, I solved it, it was the spacing that was the issue!
Thanks for responding.
No, I did not fix this yet.
So, which spacing are you referring to?
