Telegram sending no notifications to more users, only to the first id
i use telegram to send photos and notifcations. All works fine but only to the first chat id.
The other chat id gets no massages. Which one of the id’s is the first makes no difference.
The first ID gets the message the second not.
Telegram Broadcast
telegram_bot:
  • platform: broadcast
    api_key: x2x2x2x2x2x2x2x2x2x2x2x2x2x2x2x2x2x2x2x2x2x2x2x
    allowed_chat_ids:
    • 1xxxxxxxxx
    • 2xxxxxxxxx
Hope that points you in right direction.
i filled that in the two ids in the target window, but it doesn’t work again … hmm
and selfspeaking i checked the Targetbox :slight_smile:
now it works …:+1: you have two fill it in the same way as in the configuration yaml with the string…
Perfect THAnK YOU
I have the same problem. What do you mean with the same way in configuration yaml?
Can you make an example of what you put in the target box?
Thank you
this is my Configuration Yaml… the space between the hyphen and the ID is important
Is that what you mean ? If yo restart you can send messages to telegram.
Create an Automation and select: Action … Telegram bot… send message.
# Telegram Broadcast
telegram_bot:
  - platform: broadcast
    api_key: xXXxxXxXxxxXxXxxxxxXxXxxXxxxXxxXxx
    allowed_chat_ids:
      - AAAAAAAAA
      - BBBBBBBBB
      - CCCCCCCC
