Telegram tor local proxy port 9050
Hi!
ubuntu server 16.04, local tor proxy - port 9050.
  1. send message to telegram bot
curl --socks5-hostname localhost:9050 curl -s -X POST https://api.telegram.org/botXXX633034:AAHSXVi3xaBzysrhWe3Afl-XV4hNE8m0tuk/sendMessage -d chat_id=763244536 -d
  • works
  1. Home assistant - sending through a local proxy does not work
    configuration.yaml
    telegram_bot:
  • platform: polling
    api_key: !secret telegram_bot_api_key
    proxy_url: !secret telegram_bot_proxy_url
    proxy_params:
    username: !secret telegram_bot_proxy_username
    password: !secret telegram_bot_proxy_password
    allowed_chat_ids:
    • !secret telegram_bot_allowed_chat_id1
    • !secret telegram_bot_allowed_chat_id2
secrets.yaml
telegram_bot_api_key: XXXX33034:AAHSXVi3xaBzysrhWe3Afl-XV4hNE8m0tuk
telegram_bot_proxy_url: socks5h://127.0.0.1:9050
telegram_bot_proxy_username:
telegram_bot_proxy_password:
telegram_bot_allowed_chat_id1: 763244537
telegram_bot_allowed_chat_id2: 763244536
notify.yaml
  • name: telegram666
    platform: telegram
    chat_id: !secret telegram_bot_allowed_chat_id2
2.2 - error
Error setting up platform polling
File “/srv/homeassistant/lib/python3.6/site-packages/telegram/utils/request.py”, line 125, in init
from telegram.vendor.ptb_urllib3.urllib3.contrib.socks import SOCKSProxyManager
File “/srv/homeassistant/lib/python3.6/site-packages/telegram/vendor/ptb_urllib3/urllib3/contrib/socks.py”, line 27, in
import socks
ModuleNotFoundError: No module named ‘socks’
File “/srv/homeassistant/lib/python3.6/site-packages/homeassistant/components/telegram_bot/init.py”, line 251, in async_setup
platform.async_setup_platform(hass, p_config)
File “/srv/homeassistant/lib/python3.6/site-packages/homeassistant/components/telegram_bot/polling.py”, line 15, in async_setup_platform
bot = initialize_bot(config)
File “/srv/homeassistant/lib/python3.6/site-packages/homeassistant/components/telegram_bot/init.py”, line 334, in initialize_bot
urllib3_proxy_kwargs=proxy_params)
File “/srv/homeassistant/lib/python3.6/site-packages/telegram/utils/request.py”, line 127, in init
raise RuntimeError(‘PySocks is missing’)
RuntimeError: PySocks is missing
  1. how to make work through a local proxy?
  2. sorry for bad English
Try installing PySocks first. Something like this MIGHT work, depending on how you installed home assistant:
pip3 install PySocks
Thanks for the answer!
Installed PySocks, error same
You didn’t install it in the right place. It looks like you’re using virtualenv for HASS, and you probably didn’t install it in the virtual environment. You should try:
First - Change to the user that is running home-assistant using su/sudo
cd /srv/homeassistant
./bin/activate
./bin/pip3 install PySocks
source bin/activate
sudo ./bin/pip3 install PySocks
All Ok!!!
Спасибо тебе добрый человек!
