Telldus dimmer - why shown as switch in HA?
I have set up a Telldus Dimmer with Telldus Duo on a Pi2. I can use fade/dim using command line but in HA (setup using Light-component) it is shown just as a switch with ON/OFF.
Why does it not allow me to fade/dim ?
TELLSTICK
tellstick:
signal_repetitions: 2
switch:
  • platform: tellstick
light: # Dimmer
Hey @matlun,
Click on the component name (D1). If it supports dimming you should see a slider in the component details.
There is currently no support for dimming :frowning:
Dimming is supported for the TellstickHub (https://home-assistant.io/components/tellstick/)
but nor for Telldus Live (https://home-assistant.io/components/tellduslive/)
Thanks @davedan, that works great with Telldus Duo! Why didn’t I think of that?
(I add the following if others have a need for it)
The dimmer remembers it’s last setting so when switched on it defaults to that setting.
I can then click the icon or name and use the slider to change setting of the dimmer.
